thinair
![]() Join Date: Jun 2004
Temp guage problem
My guage pegs in seconds flat! but the truck isn't overheating. The guage is good and the sending unit is new (broke the old one changing motors). I have the green wire ran to the sender. I do not have any power at the firewall on that wire. All the fuses are good. I soooo hate chasing electrical!!
#2 | |
Re: Temp guage problem
//RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
I just had a problem with my oil sending unit, it was leaking oil all over. Yeah what rfmaster said trace your wire back through your firewall plug. It's not that long of wire. And Idk what difference is in color code between years but on my truck the wire is orange.
1979 chevrolet k-20 "O'l Blue" 350 muncie 465. Project in process. |
78K & 79C Jimmys
should be green
is it the right sender?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
I had the wrong sender in my CCSB.
I think it was a newer sensor. It would do just what you are saying. It would jump up very hot very fast. I checked the radiator and thermostat housing with an IR thermometer, it was normal. I changed the sender to the correct one and it solved my problem. Posted via Mobile Device
thinair
Please post your truck model year (and engine details). IRC 70's square bodies use single green wire (that's what I have in my 75) routed to a temperature sending unit bolted into driver side cylinder head. Trucks equipped with factory gauges can use SBP TS-6, or Wells TU-5 sending units if OE is damaged or no longer available. TU-5 appears to be the closest equivalent - not perfect, but good enough. //RF
thinair
1982 K20, 350ci........ I thought about the wrong sender also ( I did buy it at a national parts store). The truck was originally a diesel. So I was thinking maybe diesel gauge/ gasser sending unit? But I removed the cluster and the part number on the circuit board is the same as a gasser that I have layin. When I hit that terminal on the firewall plug with the test light.....no power.
Posted via Mobile Device |
Oh crap I'm sorry I was thinking of a completely different sender. haha I was tired when I read the thread last night... Yeah green wire... You havn't had it melt on your exhaust manifold had you? Do you still have your old sender to compare to your new one?
#9 | |
//RF
Just here to tinker
![]() Join Date: Jun 2008
Sounds like your new sender has the wrong ohms, this happened to me on my '60. And I do believe the diesels had different senders but I doubt that is what they gave you unless you stated you had a diesel.
Try this link, I know a lot of guys on the 60-66 side have found there senders to be correct for the model year. http://www.lectriclimited.com/
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
