Closed Thread
Old 02-10-2012, 02:11 PM   #4626
Woogeroo
Re: What did you do to your truck today?
Oil / oil filter change and lubed the front end.
Then I proceeded to run out of grease in the grease tube without a spare tube.
whoops.
-W
Woogeroo is offline
Old 02-11-2012, 11:45 PM   #4627
towersddg9
towersddg9's Avatar
Finally got a set of headers that fit good, did not have to trim the frame. This was set 3 as the first set of Hedman's wouldnt work with the motor moved to the forward hole, I also tried some patriot shorties, those were close but hit the CPP mounts
towersddg9 is offline
Old 02-12-2012, 12:31 AM   #4628
jbgroby
jbgroby's Avatar
Mounthed the front clip.
jbgroby is offline
Old 02-12-2012, 01:30 AM   #4629
Turkey
Turkey's Avatar
cleaned up some areas and reinstalled my speakers 'cause I found my VH Diver Down cassette. Classic tunes for "parts" running this afternoon.
Turkey is offline
Old 02-12-2012, 01:49 AM   #4630
sigshooter
sigshooter's Avatar
put the inline back in
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline
Old 02-12-2012, 11:39 PM   #4631
E911manager
Not a da^^ thing.. It was to freakin cold...
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline
Old 02-13-2012, 12:50 AM   #4632
shortbed70
shortbed70's Avatar
Froze my butt off in the shop but managed to finish mounting my alternator,new flexplate installed,and got the throttle linkage done and tight.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline
Old 02-13-2012, 12:51 AM   #4633
shortbed70
shortbed70's Avatar
Did I mention freeze...
Troy
Big Red Dog build
Old 02-17-2012, 11:12 AM   #4634
meat-head
meat-head's Avatar
Installed a new retro radio and kick panels with speakers.
meat-head is offline
Old 02-17-2012, 11:20 AM   #4635
64c20crewcab
64c20crewcab's Avatar
I did full rear brake job on my 64 C20 Crew Cab using 1980 K20 front rotors, calipers and lines. Did the swap in 06 and 1 caliper locked up last weekend so i swapped all out yesterday. The mounting brackets are for a 14bolt disc conversion and work on the Eaton H052 / H072. From Great Lakes Offroad...
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline
Old 02-17-2012, 01:08 PM   #4636
K98AL
K98AL's Avatar
Tell some details on those kick panels w/speakers! They look great - how do they sound?
As for me, I picked up a new bed and tailgate from Craigslist and pulled out my radiator and heater core. Taking them to the radiator shop....got most of the front end disassembled.
K98AL is offline
Old 02-17-2012, 02:39 PM   #4637
meat-head
meat-head's Avatar
They sound ok. Just running deck power now so cant really say for sure until I get an amp. Also the speakers are pretty low, so its a good idea to also run a speaker or pair of speakers in the factory dash to balance the sound.
Old 02-17-2012, 11:33 PM   #4638
joedoh
joedoh's Avatar
tried to get an alignment and ran into low truck prejudice.
"wont work on that its lowered"
actually its channeled so its really only 2 inches or so lower than stock.
"nope"
so tomorrow I get to find a new alignment shop.
joedoh is offline
Old 02-18-2012, 12:08 AM   #4639
Twiztid_66c10
just ordered my dom 2600's for the front. got my sectioned cross member paid for. Ordered a running 350 to replace my old 6 from a local wrecking yard they will deliver it thurs. also ordered my new wiring harness from speed way. so a pretty productive day!
1966 C-10 long wide- currently with 2 3/4 sectioned crossmember, 3 inch cupped a arms with 2700 bags, 67 master cylinder, in the middle of a v8 swap,
soon custom rear wishbone set up and bags
1942 chevy/divco ambulance
1937 chevy truck
Twiztid_66c10 is offline
Old 02-18-2012, 04:22 AM   #4640
62-One-Ton
62-One-Ton's Avatar
I pulled my windsheild and started to "discover" where I need to do some body work.
62-One-Ton is offline
Old 02-18-2012, 09:31 AM   #4641
mustangchef
mustangchef's Avatar
put in rosewood armrest/doorpulls, three point seat belts,spring loaded the glove box door
Don't stop, its harder to hit a moving target.
mustangchef is offline
Old 02-18-2012, 10:44 AM   #4642
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Do you have pictures of the armrest/door pulls and the spring loaded glove box?
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline
Old 02-18-2012, 10:54 AM   #4643
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
What I did yesterday was mock up a front end on my 71 frame that I am converting to take a 63-66 cab and front end.
Today, I am taking the front clip and cab back off, hopefully get the nose of the 63-66 frame horns grafted to to the 71 frame, pulling the suspension, again, and cleaning everything up to be ready for paint.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 02-18-2012, 06:09 PM   #4644
mrfixit4818
Put on my new headlights w 5600k bulbs and wired up 2 relays!nice!!!!!!!
mrfixit4818 is offline
Old 02-18-2012, 07:01 PM   #4645
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Repaired the leaky float on the gas tank sending unit. I kept wondering why it would only hit a half tank when full.... now I know.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 02-18-2012, 08:16 PM   #4646
kenmel
kenmel's Avatar
l
m
kenmel is offline
Old 02-18-2012, 08:29 PM   #4647
Harney Boy
Harney Boy's Avatar
Pulled my Side Mount gas tank, It was in really bad shape, I kept getting rust in my Holley 750 double pumper, So time for a new Gas tank and Sending unit! Cheap on Ebaymotors.
77' 3/4 Shortbed Stepside Silverado
Harney Boy is offline
Old 02-18-2012, 08:30 PM   #4648
Harney Boy
Harney Boy's Avatar
Same problem with mine!
Old 02-18-2012, 08:51 PM   #4649
X24
Installed a new in dash speaker, seatbelts and replaced my fuel pump.
X24
1964 chevy c10 step side
230ci straight six
Auto power glide
X24 is offline
Old 02-18-2012, 09:48 PM   #4650
niterider65
niterider65's Avatar
Cool Re: What did you do to your truck today?
cleaned up the mess in the shop and guess what theres truck parts on the shelves now . I can find stuff again!
niterider65 is offline
Closed Thread
