Old 02-06-2012, 04:13 PM   #1
ed2552
ed2552's Avatar
LS Swappers, What did you use, and what did it cost?
Ok, so I have decided the route for my 67 C20, and it's a 6.0L LS swap.
My question for you guys is: What kit or parts did you use, and what did it cost you?
I haven't decided which way I want to go, whether it's a full FI/DIS swap, carb and DIS or carb and dizzy setup, (#1 or 2 are most likely), but I want real world, I did this and it is now running perfect numbers. I plan on using a JY engine, which has risks, but is significantly cheaper than any other options.
Let me hear it!
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 02-06-2012, 04:17 PM   #2
Redleg
Redleg's Avatar
Re: LS Swappers, What did you use, and what did it cost?
http://67-72chevytrucks.com/vboard/s...d.php?t=456787
Probably everything you need to know!
Joel
Some trucks in the air, some layin' frame.
some are super cool, and some kinda lame.
Some kinda slow, and some really fast.
some run on 110,and some on pump gas!
Redleg is offline   Reply With Quote
Old 02-06-2012, 04:20 PM   #3
robnolimit
robnolimit's Avatar
Headman headers, holley or trans-adapt plates, and bolt it in. Use the web directions to rework your harness, and have the ECU flashed. Then run it.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 02-06-2012, 05:19 PM   #4
mcbassin
Still Learning
mcbassin's Avatar
Let me hear it!
I didn't use any kit for mine. I bought all the parts seperately or made parts that I could make. Not sure anyone is offering a direct swap kit?
As far as cost,
I'm into mine for about $2700 including Engine transmission, exhaust, fuel system electrical, PCM reflash and misc. other expenses.
You could probably do it cheaper or spend WAY more. Mine is a 4.8/4L60 bought on Craigslist. You will have a bunch in a 6.0 junkyard or otherwise.
I would be happy to help you any
way I can if you decide to pull the trigger.
Old 02-06-2012, 06:26 PM   #5
black_sheep454
One thing to watch for if you want to run the front mount dist is that not only do you have to buy a dist you also have to buy a kit that includes the new front cover, new water pump, new harmonic balancer, and pulley kit to clear the new cover that cost around $1500. When I do mine I'm gonna run an intake/carb setup with a msd box to control the coil packs.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 02-06-2012, 07:53 PM   #6
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Originally Posted by black_sheep454 View Post
one thing to watch for if you want to run the front mount dist is that not only do you have to buy a dist you also have to buy a kit that includes the new front cover, new water pump, new harmonic balancer, and pulley kit to clear the new cover that cost around $1500. When i do mine i'm gonna run an intake/carb setup with a msd box to control the coil packs.
posted via mobile device
hhhmmmmmmm
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 02-06-2012, 11:47 PM   #7
trkfrk
trkfrk's Avatar
Here are a couple of items that made my swap easy.
Motor mount kit from CPP part # CPLS1-K. kit comes with plate and hardware.
Headers - I installed Doug Thorley's, they fit like a glove. You can find them for under $500 shipped.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 02-07-2012, 12:40 AM   #8
Ackattack
Ackattack's Avatar
Just added mine up (5.3L), $2725. That includes headers, full exhuast 4L60E tranny, wiring harness, multiple fittings, fuel tank, sensors.
I did some swapping and selling, so that includes those items too. Such as, I bought the engine with a corvette oil pan, sold that bought a truck pan, sold that got an F-body pan. Did similar things with wiring harnesses too.
For me, since my truck didn't come with an engine or tranny, it was pretty much a no brainer. I decent running 350 and TH 350 with headers and exhaust and everything else probably would have run at least $2k
Ackattack is offline   Reply With Quote
Old 02-07-2012, 02:48 AM   #9
5150.4.67
I'm at about $3800, however, I started with the LQ4 and bored it to a 370, added LS6 heads, cam, etc. Using 4l80e trans. I used ECE's motor mounts and the Thorley headers are simply fantastic. If you go with a custom FI fuel tank, add at least 800 clams to that figure. Plug and play harness? Another 800 bones.
I stayed with factory flashed puter and modified my own harness. I've had the GMPP dizzy setup, but sold it when I mocked it up. Not real appealing to me and seemed like a step in the wrong direction.
That's my $.02.......
Good luck and keep us posted.
5150.4.67 is offline   Reply With Quote
Old 02-07-2012, 01:49 PM   #10
ed2552
ed2552's Avatar
Great info guys, this is what I need.
I was leaning away from the GMPP dizzy setup, but wasn't sure. But $800 for the DIS versus $1500 for a dizzy? No question, lol. I'll probably run a stock intake and FI setup, as it's a 3/4 ton truck, i'd rather have the torque from the truck intake than the looks from the LS1/6 intake.
Old 02-10-2012, 06:43 PM   #11
Daaaanz67
Trkfrk can you point me in the right direction for those dt headers for under 500.00 shipped?
Daaaanz67 is offline   Reply With Quote
