Old 01-27-2012, 06:13 AM   #876
bbbc10
Diggin The SquareLife
Re: my 80 build
Originally Posted by flamingbig10 View Post
mine was like 59", I upgraded to the 1350 u joints, and forged pinon yoke with 1350 u joints
thanks for the info!
bbbc10 is offline   Reply With Quote
Old 01-29-2012, 03:31 AM   #877
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-30-2012, 12:09 PM   #878
truckzilla
truckzilla's Avatar
Thumbs up Re: my 80 build
Coming along nicely Aaron. My question is what are the two little components in the picture right before the dash pic? Also I've been meaning to ask, with the smoothed firewall, what are you doing about the wiper motor?
And thanks for the lead on headers that will fit our frames.
truckzilla is offline   Reply With Quote
Old 01-31-2012, 01:19 AM   #879
flamingbig10
6.0 powered square
Re: my 80 build
thanks, one is a fuse holder and the other is a module for the electric fans, tonight I finished wiring the headlights, park, and side marker lights every think seams fine but my turn signals click really slow with the headlights are on, and when I had the bulb and grounds disconnected and hit the turn signal my starter relay clicked for some reason
Aaron
Old 01-31-2012, 11:07 AM   #880
truckzilla
truckzilla's Avatar
Thanks Aaron, I guess I'll be needing to get a fan relay as well, but I need to first get the radiator and fans. I'm still wondering about your wiper motor location though? And did you reinforce the firewall for your brake booster after you removed the funky stamped factory bracing? Man, that's a butt ugly piece that GM came up with. Anyway, I hope you get the wiring issue resolved because I don't think that your starter relay should have clicked like that.
BTW you wouldn't still happen to have the template you made for your firewall skin would you?
Old 01-31-2012, 08:20 PM   #881
flamingbig10
6.0 powered square
Re: my 80 build
the wiper motor is going to mounted upside down on the passenger under the cab cowl, the brake booster bracket is still there
Aaron
Old 02-01-2012, 11:11 AM   #882
truckzilla
truckzilla's Avatar
Re: my 80 build
Hey Aaron, great minds think alike. That is where I'm moving my wiper motor to as well. Having the cab all gutted, I noticed a hole in the passenger side of the firewall bulkhead that had a vacuum line and gromet going though it. That gave me the idea of trying to stab the motor shaft over there and fab up the mounting bolts. I'll probably end up putting the washer bottle under there as well since I'm wanting the engine space to be really clear of clutter. I'll have to come over to Mesquite some Saturday and see how you're doing it if that was alright.
Old 02-03-2012, 01:53 AM   #883
flamingbig10
6.0 powered square
Re: my 80 build
That sounds good any Saturday is good with me
got a little done today mocked the fan up and wired it in, worked on getting the horn working through the horn button no luck there, and then was messing around with my headlights, noticed the right turn signal indicator was lit then spend a good 30 minutes checking wiring, then I pulled the turn signal bulb out and put it back every thing was working fine also found the bulb to fit loosely in the socket
Aaron
Old 02-04-2012, 03:03 AM   #884
flamingbig10
6.0 powered square
Re: my 80 build
worked on getting the steering column back together, had trouble with the upper bearings seating worked on it about a hour finally every thing fell into place, now the horn work through the canceling cam, then I tested the electric fans took a little adjustment every thing works up to par the fans come on around 190, I let it Idle for 20 minutes no problems, took it around block for 10 minute drive what a great feeling that was
Aaron
Old 02-05-2012, 11:53 AM   #885
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 02-05-2012, 01:19 PM   #886
truckzilla
truckzilla's Avatar
Re: my 80 build
Hey Aaron,
It was good to talk to you yesterday. I'm sorry I got back to Fort Worth before we made contact. It looks like three Saturdays from now ( the 25th ) will be the next chance to make it out your way.
And thanks for the close up pics, I can see the goofy brake/steering column brace that you smoothed around. I'm off to see what I can do on mine today, but it's cold as heck and I have to work outside on it!
Old 02-05-2012, 01:26 PM   #887
truckzilla
truckzilla's Avatar
Talking Re: my 80 build
Oh yeah, I'm glad you got to take a quick spin in 'er, but your inspection and tags are out of date. Wouldn't want you to be ticketed or anything!
Old 02-11-2012, 01:15 AM   #888
flamingbig10
6.0 powered square
Re: my 80 build
sounds good, my dad got on to me for driving it around with no tags, he said you'll get a ticket, I just laughed and I said I didn't put my foot in it.
A little work accomplished, started looming the headlight wiring, installed a horn contact for my billet specialties steering wheel, and pick up a reman wiper motor
before
after
Aaron
Old 02-15-2012, 01:40 AM   #889
flamingbig10
6.0 powered square
Re: my 80 build
I"ll bolt the other one on tomorrow
Aaron
Old 02-15-2012, 01:18 PM   #890
truckzilla
truckzilla's Avatar
It's getting closer Aaron. Oh, are you going to be home this Saturday morning? I was going to try and make it over there before lunchtime and see your ride in person.
Old 02-16-2012, 12:31 AM   #891
flamingbig10
6.0 powered square
Re: my 80 build
I'll be home
Aaron
Old 02-17-2012, 06:45 PM   #892
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: my 80 build
Looks like she is getting closer to burn outs..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 02-18-2012, 03:22 AM   #893
flamingbig10
6.0 powered square
Re: my 80 build
I have already spun the tires 20+ feet but neighbors weren't to happy about I got the vehicle registration and got the truck ready for the safety inspection I drove it about 8 miles filled it up with gas ended up spilling all over place, the while I was driving I slowed down real quick at the traffic light, the truck died and lost complete power for about 10 seconds then every thing came back on and started right when I got back home I founds the positive battery terminal made contact with the battery tray and and burned a hole in the tray and melted the terminal but so fare every thing else look fine, also fixed the fuel filler so it will vent, I did give it a good 3/4 throttle while I was passing a car at 30 mph, the rear end felt light and it chirped the tires when it shifted
Aaron
Old 02-18-2012, 03:25 AM   #894
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 02-20-2012, 10:23 PM   #895
PokeyC10
PokeyC10's Avatar
Re: my 80 build
Just read the whole thing... haha! Yeah I had too much free time!
Looks great and the only question I had was about the harness. Are you doing the work the the harness or someone else?
Art
PokeyC10 is offline   Reply With Quote
Old 02-21-2012, 12:20 AM   #896
PokeyC10
PokeyC10's Avatar
Re: my 80 build
Art
(ugh cant edit my previous post)
Ok I went back and found the info around page 30 on the harness.
Thanks again for posting all this information over the years.
Art
Old 02-21-2012, 01:12 AM   #897
flamingbig10
6.0 powered square
Re: my 80 build
thanks, I got the seat belt nuts repaired cut off the old ones and added a new grade 8 washer and nut, I was able to find the riser for the red top secure it better, and tried to re flare the fuel sender feed line with no such luck looks like I need to get a new sender a just use high pressure fuel hose
Aaron
Old 02-21-2012, 01:41 PM   #898
truckzilla
truckzilla's Avatar
Hey Aaron,
It was great to meet you last Saturday and see the the mighty beast in person! Wow, you have really put together a killer ride guy! And again, I want to thank you for having done so much of the research on stuff that I'll need to get to on my POS (I know it won't always be one though). Thanks for giving me your time the other day and congratulations again for having made it to Eagle Scout back when you were younger.
Larry
Old 02-22-2012, 09:53 AM   #899
flamingbig10
6.0 powered square
Re: my 80 build
Thanks Larry, I ordered a sending unit from orielly auto parts should be here today, and get some high pressure fuel hose, will see how it goes if it goes well I'll be driving it to work tomorrow
Aaron
Old 02-22-2012, 10:55 AM   #900
truckzilla
truckzilla's Avatar
Re: my 80 build
Awesome! I wish I were driving mine to work. For you, how far away is work?
