Old 02-10-2012, 10:23 PM   #1
Bigb401
Ammeter to voltmeter upgrade
I'm upgrading my alternator to a 10si. My blazer is a '72 and has a ammeter in it now. Since my new alternator will put out more amps than the stock ammeter is rated for I want to change it to a voltmeter. Does anyone know of an aftermarket voltmeter that looks stock and will fit in the factory dash?? Any information or ideas about any of this would be greatly appreciated.
Proud to be IBEW Local 2150
Bigb401 is offline   Reply With Quote
Old 02-11-2012, 12:59 AM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Ammeter to voltmeter upgrade
I've run a 12si from Summit (made by PowerMaster) that's good for 140amps.
Been running the same alt since 2001.
It's been connected to the factory harness and Amp gauge since installed.
I have not had any issue's to date.
Here's the tag that came with the alt. Note that it tested 23amps more than advertised
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-11-2012, 06:56 PM   #3
Bigb401
I'll be adding more more power sucking components to my blazer and don't want to run the risk of fire so I have decided to look for a voltmeter to replace it and look like it belongs with the other meters. Does anyone know of a voltmeter replacement?
Old 02-11-2012, 07:26 PM   #4
BobbyK
BobbyK's Avatar
If your dead set on using a voltmeter I'd look at the same era in gm cars.
Maybe a couple years newer.
The font and style of the gauge may be similar to our ammeter but not dead on.
Of course nothing will bolt in. You will have to do some kind of fabrication.
Old 02-11-2012, 07:37 PM   #5
BobbyK
BobbyK's Avatar
70-79 firebird.
77+78 Blazer voltmeter.
Old 02-12-2012, 03:39 PM   #6
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I'll have to get you a pic of mine, but its just an aftermarket voltmeter I put in place of the ammeter. It had a black face already, just had to take out the ammeter and put the voltmeter in.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
