Old 02-14-2012, 12:54 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Diagram for factory ground locations?
IM having a weird electrical issue and i think i may have figured it out.
How many ground locations are there? I currently have my battery going to the block, then the frame grounded to the cab. THATS IT!!!! That isnt enough is it???
its a 71 chevy stepside. Can someone tell me what i should ground???
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 02-14-2012, 01:05 PM   #2
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Diagram for factory ground locations?
You need the engine grounded to the cab (rear of block to firewall), also there is a ground from the bed to the frame and you could run one from the core support to the frame.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 02-14-2012, 01:07 PM   #3
lyrikz
PITbut
lyrikz's Avatar
Sounds good. Any others??? Whats fuinny is EVERYTHING still works but im having random electrical issues. My compressors turn on and my radio turns off.. Hard corner radio turns off. Occaisionaly electric issues. I check the grounds, but then i realized, hey, not much is really grounded. ahaha..
We will see.
and sold.
Old 02-14-2012, 01:58 PM   #4
camrycurt
camrycurt's Avatar
I think most guys on here will tell you that you can never have enough grounds.
In addition to those already mentioned, I added the following to my truck:
1. From the engine block (where the negative battery cable was tied in) directly to the frame.
2. From the negative battery terminal to the sheet metal above the passenger inner fender.
3. From negative battery terminal to core support.
4. I also ran a special ground from the block/negative battery cable tie-in directly into the cab under the dash. I use this one to ground random stuff in the cab (like the wiper motor, etc.) so I know that I'm tying into a known good ground.
Also, make sure you're using big cables for the ground straps and that every connection is clean, bright, and tight. Little 10 or 12 guage wires aren't going to do the job.
My truck is mostly rust and bondo and so far (knock on wood!) I haven't had any electrical issues.
Hope that helps.
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 02-14-2012, 02:07 PM   #5
cdowns
cdowns's Avatar
grounding is not just a case of a few random ground wires// every light bulb gauge motor horn EVERYTHING needs to b grounded to work
electricity is a 2pole system hot and ground// electric out from the battery and electric back into the battery// positive negitive
