02-14-2012, 12:33 PM | #1 |
PITbut
What are you guys using for air tank drains?
I have a 5 gallon tank that sits outside the truck and i have replaced the drain cock twice. They always seem to start leaking for some reason. IM just using the cheap ones you would put on the bottom of a compressor.
Anything out there that would be better???
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
02-14-2012, 12:59 PM | #2 |
Re: What are you guys using for air tank drains?
Somethink like a big truck I would think.
http://lelandbrake.com/images/catalog/423-425.pdf The L1374
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
02-14-2012, 01:04 PM | #3 | |
PITbut
02-14-2012, 05:41 PM | #4 |
needs more $$$
I ran a 1/4" ptc off the bottom of my tank and connected it using some left over air gauge line to a schrader valve next to my license plate. It should serve as both a drain as well as spot to fill up the tank if ever needed. Not incredibly noticable if you ask me:
1970 2wd Blazer |
02-14-2012, 05:43 PM | #5 | |
PITbut
02-14-2012, 06:00 PM | #6 |
If you check with your local aftermarket truck parts supplier in your area you might be able to pickup an autodrain that screws into the bottom of tank they usually drain at 120psi
02-14-2012, 07:06 PM | #7 |
needs more $$$
I haven't had any air in it yet but figured that you'd just push the schrader pin in to let air out and all the water would come out 1st since it would be at the bottom just like normal.
1970 2wd Blazer |
