Justified!
Who has side exhaust?
I'm thinking of re-doing my exhaust, and having my exhaust come out in front of the rear tires.
Right now I have mid-length headers, with an x-pipe and 2 Pypes Violator mufflers......and I have it dumping over the rear axles. Can I keep the x-pipe, or do I need to run just straight pipes, and a smaller muffler to be able to do this? I have looked at maybe cherry bomb glasspacks or something along that style to try and make it fit. So any help, what you run now, what you have run would be great! And pics of course..... Thanks Chad
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny
Re: Who has side exhaust?
My 63 has cherry bombs and dumps out in front of the tires. I don't have an x pipe, but I think it would fit fine. It dumps out quick enough that out may not matter. When I go through a drive through I have to shut it down because all they hear is the exhaust.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
i guess it depends on what you do with the truck also. I have had trucks that dumped in front of the tires and ya it sounded cool and was plenty loud i wouldnt do it on a daily driver again. if it was just a weekend cruiser then ya. as far as mufflers go keeping the x pipe might limit you on what you can use in a big way especially on a short box depending on how far tucked under the truck you want them. i would go straight pipe myself maybe put an H in it somewhere and go with it.
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
meowMEOWmeowMEOW
I run 2.5" striaght to 2.5x18" magnaflow resonators (not mufflers), then right out the step.
Its loud, it does drone on the highway, and the position of the tips blows noise and hot air RIGHT into the window of most passenger cars. Perfect.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
1# Drobmember in Germany
![]() Join Date: Aug 2008
Here is mine ........with 2,5" and Flowmaster Series 44 Muffler , no X-pipe
Pat |
Who Me?
Here is what I have on both side. Cherry Bombs into these 4" X 24" tips. It sounds awesome!!
![]() Here is the other side.
Steve1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
I plan on using a rectangle exit but do not have them made at this point. I think Borla or mega flow has a few system that you could get some ideas from
62 long box with a little SBC ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
Who Me?
Look into the Gen 4 Camaro tips. They are the shape your looking for.
Are your mufflers in between or on the outside of your frame rails and if they are in between how do you get around your truck arms in the rear? I have a 62 and it seems like the only way for me to run my exhaust in front of the tire is to put the mufflers under the doors. But I am worried that that will cause two much noise inside the cab.
![]() Join Date: Jan 2011
I keep thinking about these under the bed steps...
http://www.jegs.com/i/JEGS-Performan...ductId=1353766 |
those are cool.
I'm planning for 3" side exit exhaust for my '66. Will be running it through the crossmember and frame for more ground clearance. I won't have room for over-the-axle pipes with the frame bracing that will eventually be welded in.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Justified!
Thanks guys, I'm not going to use this as a daily driver, so dumping in front of the tires is not a big deal for me.
I thought about trying to find some dual exhaust tips to put on it, I have seen a truck somewhere with that and it looked pretty cool. Right now my exhaust is inside the frame rails also, so I might have to move it to outside to do this....
It's Better With Nitro
Three-inch exhaust to the outside of the frame, turn-outs in front of the rear tires...muffler mounted behind the cab. The exhaust is positioned above the bottom of the frame rails behind the front shocks...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#15 |
![]() Join Date: Jun 2010
2.5" Magna flows w/ 2.5" tubing in and out...
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
#16 |
Any drone in the cab with this set up?
#17 |
That looks like a pretty big hole you will be making in your frame rails. I think the outside the frame route would be easier and safer.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#18 | |
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
#19 | |
#20 |
Yea, a little. The V6 has a unique sound though and we don't find it all that unpleasant.
#21 |
dumps forward of the rear tire.
The price of cool aint cheap. |
#22 | |
Who Me?
#23 | |
On the inside just to strengthen it more. I am a certified welder so I'm not worried about mine not being strong enough. Posted via Mobile Device
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#24 |
1 thing at a time is progress.
Very cool solution. Looks nice!!
Alan
Philippians 2:14-16 |
#25 |
We just did a burb the same way (2 1/4" in and out of Magnaflows)...good sound, good clearance, above the frame rails for the most part.
| Bookmarks |
