Old 02-13-2012, 11:29 PM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Hard Lines 101
Due to the effects of ethanol on fuel lines I am wanting to run a hard line from the pump to the carb. I do not get the whole AN thing probably because I have not taken the time to learn the conversion, etc. I am thinking of buying some aluminum line to try to learn with and then possibly replacing it later or with stainless. What tools and parts are recommended to run hard line from the stock SBC pump to an Edelbrock 600? What size line is best for a stock set up? How big of a learning curve is there in learning to flare the fuel line? Any recommendations or setup? Thanks KT.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 02-14-2012, 12:24 AM   #2
Toms1968
Toms1968's Avatar
Re: Hard Lines 101
Funny you bring this up. I am trying to run the hard line as well. I spent 2 hours tonight, wasted 3 lenths of hard tubing and still have no lines. I am running a Holley 650 Double Pumper, on a SBC. I bought the fuel rail and I'm trying to bend 3/8 line with a cheap bender. Tomorrow I'll be buying a Quality bender and starting over. I will be following this thread very closely, so I'm hoping others chime in with some usefull advice. Good luck.
Toms1968 is offline   Reply With Quote
Old 02-14-2012, 10:58 AM   #3
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Hard Lines 101
I have always just modified the stock hard line with some rubber line and called it good but I see posts all the time where people are knocking someone running something other than hard line. I am surprised at the lack of response.
Old 02-14-2012, 03:27 PM   #4
67chevemall
67chevemall's Avatar
Re: Hard Lines 101
My new holley carb came with rubber hoses to connect the two bowls to the hardline at the front of the engine. I just used them but it is on the list to replace them with steel ones.
I have a old tool to flare the lines, dope tape, and a few fittings. to bend the lines I heat them on the fire and bend over a fat pipe by hand.
I have my fuel lines running far out in front of the engine. Not sure why the factory runs fuel lines on a hot engine. You want the fuel as cold as you can get it.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-14-2012, 10:00 PM   #5
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Hard Lines 101
Anybody want to share some tips?
Old 02-15-2012, 12:12 AM   #6
geezer#99
geezer#99's Avatar
Re: Hard Lines 101
Not the easiest job in the world. Frustrating!!
I use a bender like in the link. Probably available at Home Depot. In the plumbing tools section. Easy to use.
http://www.bikudo.com/product_search...ct_368_90.html
Your local auto parts store should have some pre-built tubing lines in various sizes and lengths. Pic up some and practise your bends. Use some coat hanger wire to make a template and transfer it to the tubing. You'll screw up a few times. Everybody does.
If you're flaring practise on that tubing. It's not stainless. Easier to learn on. Stainless is very hard to flare. JMHO. You need to get the right grade. Softer type. Sorry I don't recall the rating. Get a good flaring tool. Don't cheap out. Quality costs. Mine was 100 bucks. Here's an example.
http://www.ntxtools.com/network-tool.../OTC-6504.html
Get a small tubing cutter too. Home depot has them too. Here's a small one. Works in tight areas.
http://www.homedepot.com/buy/plumbin...ter-41599.html
When you make your flare connections don't use any sealant on the threads. The seal is made by the flare. If you have a leaker at a connection then lap it. By that I mean tighten it, loosen it, tighten it, loosen it a few times so the flare cuts it's own seat.
Have fun!!
geezer#99 is online now   Reply With Quote
Old 02-15-2012, 12:18 AM   #7
longbed67
longbed67's Avatar
Re: Hard Lines 101
Agreed dont get a cheap double flare tool if you do your flares will turn out like crap and possibly leak. Like he said practice on the end a few times before cutting the proper length plus a little extra. If your new to it, dont go with stainless, it is MUCH harder to bend and flare properly. just my .02
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 02-15-2012, 01:14 AM   #8
geezer#99
geezer#99's Avatar
Re: Hard Lines 101
OOPS!! Forgot!!
Before you put a flare on the end make sure you slide the fitting on first and in the right direction.
I learned the hardway. LOL!!!
Old 02-15-2012, 01:16 AM   #9
webfoot
Re: Hard Lines 101
AN is easy, all sizes are stated in 16ths of an inch. so 6 AN = 3/8 fuel line size, 8 AN is half.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 02-15-2012, 01:20 AM   #10
Musclerodz
Re: Hard Lines 101
just to drive everyone insane here.
http://www.bentcustomandperformance.com/
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 02-15-2012, 01:36 AM   #11
geezer#99
geezer#99's Avatar
Re: Hard Lines 101
No doubt the guy has mad skills but I'm sure he had a pile of crappy bent lines his first time too!!
Old 02-15-2012, 03:12 AM   #12
Blue72slab
Re: Hard Lines 101
If you want to save some time get a factory hard line and adapt it to your carb setup. I used this tool: http://www.sears.com/shc/s/p_10153_1...1&blockType=G1 and it works well but I broke one when I ran my 3/8" stainless line from the tank to the fuel pump. For that I ended up buying a long handle heavy duty 3/8" bender and it was a CHORE! Pump to carb is 5/16 I believe and there is nothing wrong with aluminum or mild steel, it will be MUCH easier to flare and bend.
Larry
1972 Chevy C20 Custom Camper
1968 Chevy Camaro RS
1980 GMC K5 Sierra Classic
Blue72slab is offline   Reply With Quote
Old 02-15-2012, 11:28 AM   #13
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Hard Lines 101
Thanks for the info guys.
Old 02-15-2012, 12:09 PM   #14
woodwright
Enjoying left field
woodwright's Avatar
Re: Hard Lines 101
Napa has some hardline that you can bend without a bender and it won't crimp.
It bends up really nice with a bender, but you can tweak it by hand if you over bend. Its got an epoxy coating, kind of a green color.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 02-15-2012, 07:39 PM   #15
68 Four on the Floor
68 Four on the Floor's Avatar
Re: Hard Lines 101
http://www.agscompany.com/faq/10
68 Four on the Floor is offline   Reply With Quote
Old 02-15-2012, 08:37 PM   #16
GRX
GRX's Avatar
Re: Hard Lines 101
I have been making my own brake & fuel hard lines for decades. Just made some line for my '69 Chevy truck. Advice I would share?
~ 1 - buy a quality flaring tool. I recently bought a Ridgid #345-DL kit and am very happy with it. Price was $85 shipped
http://www.coastaltool.com/hand_tool...aring_tool.htm
~ 2 - Tubing cutters can harden the end making the flaring process more difficult. I prefer to use a hack saw, then de-burr with a file.
~ 3 - Try some NiCopp nickle-copper alloy line. Recently bought some - a joy to work with. NAPA carries NiCopp but be forewarned, it is expensive. Much easier to bend and flare, doesn't corrode like steel, and meets all SAE and ISO burst strength requirements.
http://www.agscompany.com/automotive...ines/nicopp/11
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 02-15-2012, 08:56 PM   #17
RustyBillet
Re: Hard Lines 101
I'll post pics in a few minutes, I install oilfield safety systems, which means I do alot of tubing bending. We use fittings with ferrules so we don't flare anything, but that's more tool ethan skill. You need to measure a bend or two ahead before you bend, since you won't always be able to be able to , ie if you bend straight up towards the floorboard you won't be able to mark where to bend back horizontally. It always makes for a better look when you follow other planes, lines, angles, etc. Bend to meet your critique... or what you're happy with anyways ask if you want a few pointers, I'm no pro but I'd be glad to help.
RustyBillet is offline   Reply With Quote
Old 02-15-2012, 09:03 PM   #18
RustyBillet
Re: Hard Lines 101
EDIT, I'll grab some pics tomorrow
Old 02-15-2012, 10:59 PM   #19
BuiltwithIvy
Re: Hard Lines 101
cheap trick, buy some thicker tig welding rod at your local welding store, and bend it by hand to get the look you want, transfer to your line and voila... take your time and be patient and you shouldn't have any mistakes, and I wouldn't run hard line to your engine in general, torque moves the engine, will eventually break the line, see what new vehicles run their ethanol through, and buy some of that
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
Old 02-16-2012, 11:08 AM   #20
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Hard Lines 101
All great info. I think I am going to buy a flaring tool and give it a shot. I guess it will really pay for itself if I can manage the learning curve. RB, I am sorry I missed the chance to check out your truck at the show in November here in Tyler. I did not even know it was happening.
Old 02-16-2012, 05:21 PM   #21
long69
Re: Hard Lines 101
i wasn't able as tight a bend as i wanted to. it hard to get good pics to show but the fuel pump to carb required tighter bends than i could get. not done yet but i like my carb lines better than a $60 braided one. no pic for the pump but here is my carb lines
long69 is offline   Reply With Quote
Old 02-16-2012, 05:22 PM   #22
GRX
GRX's Avatar
Re: Hard Lines 101
TIG rod. Good idea. I have always used coat hanger wire though. A lot cheaper. One short piece of flexible hose between frame & block is all that's required. My preference is to use much hard ine as possible to avoid potential problems. And I can't stress enough how easy the nickel-copper line is to work with. You can bent it into a pretzel by hand if needed.
Also ... laying a piece of string along the bent line is a good way of measuring the total length needed.
Old 02-16-2012, 09:12 PM   #23
MrGoodpliers
MrGoodpliers's Avatar
Re: Hard Lines 101
Double flare for steel and aluminum tubing and single flare for stainless, right?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 02-18-2012, 01:14 PM   #24
BuiltwithIvy
Re: Hard Lines 101
I use tig rod because I always have a bunch lying around for whenever I need to tig something in general, and even after its bent it can still be used, and the flare is based on whatever connection you are trying to make, not the type of material
1930 Tudor Sedan
Old 02-19-2012, 11:24 AM   #25
MagmaJct
MagmaJct's Avatar
Re: Hard Lines 101
My understanding is that copper will work harden over time and crack. Does the nickel help this?
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
