09-08-2003, 12:33 PM | #1 |
The Blazer King
Which gear ratio do i run?
I bought my Blazer with a 3:73 ratio witch is obviously not enough for my 38 inch tires. What is the best combo here? I do drive it daily so keep that in mind.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
09-08-2003, 11:01 PM | #2 |
Which trans are you running? if a final 1-1 then I would suggest a 4.56-4.88 if running an overdrive then I would step down to a 5.13 or a 5.38
09-09-2003, 04:55 AM | #3 |
user # 2756
What he said. At least 4.56!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
09-09-2003, 08:48 AM | #4 |
The Blazer King
I have a TH350. I guess 4:56's it will be. Thanks.
