Re: door hinge pin kit
Those are Dorman hinge pins which will not fit in your hinges - the diameter is too big. Check the first link to a previous post I noted above. Unless you hog out the holes in your hinges with a round file the pins won't fit. I would advise genuine GM pins only.
