Closed Thread
Old 02-17-2012, 10:20 PM   #3426
67cheby
67cheby
67cheby's Avatar
Re: What did you do to your truck today!
Nice job on the kick panels
67cheby is offline
Old 02-17-2012, 10:35 PM   #3427
74baggedbug
74baggedbug is offline
Old 02-17-2012, 11:15 PM   #3428
67Slider
67Slider's Avatar
Installed the 94 amp alt from an 86 silverado. Internally regulated, 3 wire set up. Fixed the amp gauge too.
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 02-18-2012, 02:04 AM   #3429
shawno72
C/10 junkie
shawno72's Avatar
Originally Posted by Newtz67 View Post
Got my tires remounted on the rallyes and got them on the truck. Much better!
The rallies look good Newt!!
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 02-18-2012, 08:54 AM   #3430
wrwelton
wrwelton's Avatar
I installed the sound deadening insulation and started restoring the heater equiptment. I had several heaters and vent boxes to choose from so I could take the best parts of many. I sandblasted parts and applied rustmort over night. Paint it all tomorrow.
I know I can! I know i can! 72 K20 Restoration
wrwelton is offline
Old 02-18-2012, 12:26 PM   #3431
bigdog57
bigdog57's Avatar
I have been upgrading my timing chain and sprockets. Its been a real pita. I've had the most problem out of the harmonic balancer installation tool than any of it. But we are almost done. Just fixing to check on the timing.
Bigdog
bigdog57 is offline
Old 02-18-2012, 02:47 PM   #3432
Newtz67
Newtz67's Avatar
Thanks bro!
Newtz67 is offline
Old 02-18-2012, 11:52 PM   #3433
67lowered
Originally Posted by ffk View Post
made a filler panel for firewall on driver side to match passenger side..hand formed the old fashined way...a small torch , hammer and a round bar ..heated and hammered radius on panel...also cut vent cowl shorter..no need will have vintage air...im going to put a 61/2 speaker in there and a rubber grommet for the wireing harness
ffk,, nice tin work, bet that took some time,
I gotta do mine, thanks the inspiration
67lowered is offline
Old 02-19-2012, 12:46 AM   #3434
Tomahawk30
Tomahawk30's Avatar
Tinkered on the new C10 for a while today. Replaced the LOOOONG van-style oil filler tube with a oil cap / grommet, checked plugs / gaps, tested compression on all cylinders, and installed a squarebore carb to q-jet intake adapter (previous owner had installed edelbrock directly to the original intake). The old 350 still isn't running right, but it looks like the timing is WAY off. I think the previous owner dropped the distributor in without setting TDC on 1. It'll run, but the #1 wire has to be clear over past the normal #8 position, and the vacuum advance doesn't appear to be working well either. Probably going to hold off on any more troubleshooting until the new HEI shows up. Hopefully the new install will clear up all these little issues...
I also crawled underneath to check out the saddle tank setup. The tanks look great from underneath, but who knows what the inside looks like. The switch and saddle tank fuel lines are disconnected but all there if I decide to hook it back up. For now I might pull the new-ish tank out of my donor cab tomorrow and see how clean it is.
1979 Silverado C10 Shortbox - Photo Album
1977 Silverado K20 Camper Special - Photo Album
1972 C10 Custom Deluxe Highlander - sold
1971 Cheyenne Super Longhorn -sold
1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb.
1970 Chevy C10 SWB "Sprout" -sold
1972 Cheyenne K20 -sold
1969 GMC Shortbox Stepside 4x4 -sold
1972 GMC Jimmy 4x4 -sold
Tomahawk30 is offline
Old 02-19-2012, 09:51 PM   #3435
DaBigKahuna
DaBigKahuna's Avatar
Spent a great day hanging out with forum members JohnOro and V-Dog.
Oh, and we swapped out the water pump on my truck.
Thank you for the help and conversation. It was much appreciated!
DaBigKahuna is offline
Old 02-19-2012, 10:42 PM   #3436
MARIOS68PANEL
Active Member
MARIOS68PANEL's Avatar
Bought it and brought it home. after installing a new master cylinder and bleeding breaks. 1967
67 short step
71 Custom
MARIOS68PANEL is offline
Old 02-19-2012, 10:47 PM   #3437
Newtz67
Newtz67's Avatar
Nice! Congrats!
Newtz67 is offline
Old 02-20-2012, 08:37 AM   #3438
wrwelton
wrwelton's Avatar
Installed heater and rest of insulation. Ordered the adapter for 72 gas pedal to fit earlier cab from member. Watched youtube video on installation of harness.Just ordered wiring harness from American Auto Wire on ebay. $479
wrwelton is offline
Old 02-21-2012, 04:50 AM   #3439
Hard Luck
I've got grease on my mind.
Hard Luck's Avatar
Turned my truck into this!
Hard Luck is offline
Old 02-21-2012, 08:53 AM   #3440
Redleg
Redleg's Avatar
First off gorgeous truck, second, what is that hanging off the E-Brake release?
Joel
Some trucks in the air, some layin' frame.
some are super cool, and some kinda lame.
Some kinda slow, and some really fast.
some run on 110,and some on pump gas!
Redleg is offline
Old 02-21-2012, 09:20 AM   #3441
no moa
no moa's Avatar
Pine air freshner
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline
Old 02-21-2012, 09:40 AM   #3442
Redleg
Redleg's Avatar
Originally Posted by no moa View Post
Pine air freshner
thought thats probably what it was, but almost looked like a yellow thong... So i had to ask!
Joel
Redleg is offline
Old 02-21-2012, 09:46 AM   #3443
aventur1
aventur1's Avatar
Unplugged interior wire harness, I have a harness that has excellent fuse box writing and it has like new wires, very clean so replacing my old one. Removed dash and replaced the green turn signal and high beem red color caps with blue. Going with blue lghts in dash so thought why not blue turn signal and high beem. Used a blue plastic and cut out and glued on the cardboard supports in dash. Took dash pad in to get recovered in leather like my side panels are. Going to take a dremal and polish up fuse tabs in the fuse box before I install.
1968 4x4 Frame, with a 67 Cab and Bed
A Shorter Step
1999 Dodge 2500 Cummins Diesel
aventur1 is offline
Old 02-21-2012, 10:18 AM   #3444
mcmlxix
Collector of Projects
mcmlxix's Avatar
I ddnt do anything to it... bit it sprung a leak on me... heater core.... damn.
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Old 02-21-2012, 02:16 PM   #3445
74baggedbug
Still working on it
Old 02-21-2012, 02:17 PM   #3446
74baggedbug
Old 02-21-2012, 02:27 PM   #3447
Katrina/10
Katrina/10's Avatar
.69-72 Truck - YouTube
Got any pics of that adapter installed?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline
Old 02-21-2012, 04:38 PM   #3448
1quik70
Same thing I do everyday Pinky, Jumped in her and went to work! Thought about washing it but decided it was pointless!
1quik70 is offline
Old 02-21-2012, 07:18 PM   #3449
74baggedbug
Old 02-21-2012, 10:15 PM   #3450
72chevy383
Put on my No Limit Shock relocators.
72chevy383 is offline
Closed Thread
