Closed Thread
Old 02-18-2012, 10:49 PM   #4651
tincan1966
tincan1966's Avatar
Re: What did you do to your truck today?
Test fit the big block in the 'burb. Everything looking good, with only a couple slight mods needed for a little clearance. Will post pics tomorrow.
tincan1966 is offline
Old 02-19-2012, 12:05 AM   #4652
Woogeroo
replaced the heater core and the hoses going to and from, in my 1965 C10.
antifreeze in the floorboard
-W
Woogeroo is offline
Old 02-19-2012, 12:11 AM   #4653
karlvonrohr
man, went to bone yard. three pre '66 c10's got three 8 lug steel wheels.
karlvonrohr is offline
Old 02-19-2012, 07:17 AM   #4654
glos55
glos55's Avatar
The winter has been so mild here almost got her out of the barn. Charged the battery and covered her back up.
glos55 is offline
Old 02-19-2012, 02:27 PM   #4655
63CHEVY62GMC
63CHEVY62GMC's Avatar
replaced burnt-out lightbulbs in gauges, greased driveshaft, and fixed a exhaust leak on the 63
1998 chevy silverado- weekend and long trip truck
1963 chevy c-20 (black betty)- daily driver
1962 GMC wrecker- ongoing project that will never be finished
63CHEVY62GMC is offline
Old 02-19-2012, 03:10 PM   #4656
Turkey
Turkey's Avatar
re-built the Rochester 1bbl.
Turkey is offline
Old 02-19-2012, 04:16 PM   #4657
tincan1966
tincan1966's Avatar
Here's a couple from test fitting engine yesterday, also added a couple from the sheet metal I did on the driver's side floor and the new brake pedal. It's all roughed in got alot of finish work to do, but the test fitting and fab are going pretty smooth.
Old 02-19-2012, 05:55 PM   #4658
suzq044
Resident Photoshop Nerd
suzq044's Avatar
.. absolutely nothing.. unless photoshop (as usual) counts? O_o
[pondering the interior lighting for PJ]
PJ - 1966 C10 Panel --
Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn
suzq044 is offline
Old 02-19-2012, 08:45 PM   #4659
jbgroby
jbgroby's Avatar
Got the fenders back from the painter today. Could not wait to test fit one. The color is much more promounced now that I have a fender on. This Canyon Blue sure is the Cats A**.
There must be someone watching me, after I mounted the fender a REALLY spooky thing happen that made me PAUSE. On the radio Carly Simon started singing "Anticipation". I loked at the radio and then looked around the garage, weird!
jbgroby is offline
Old 02-19-2012, 08:53 PM   #4660
60_project
Made my drivers door jamb purdy. Now on to the passenger side, and door latches...
60_project is offline
Old 02-19-2012, 09:17 PM   #4661
suzq044
suzq044's Avatar
^what are you doing to your doors?
suzq044 is offline
Old 02-19-2012, 09:20 PM   #4662
hopped up
hopped up's Avatar
Rebuilt my starter and went for a cruise.
hopped up is offline
Old 02-19-2012, 10:01 PM   #4663
60_project
Shaving the door handles and putting in newer style bear claw latches... but contemplating suicide doors now that the jambs look so nice.
Old 02-20-2012, 11:26 AM   #4664
Blue Blood
Blue Blood's Avatar
Finally got the right steel wheels(late 70's for disc brake clearance) for my truck...Got the motor mount spacers finished awhile back, split & rewelded(narrowed 2") the 60' burb fan shroud to fit my radiator. I'll take some photos soon & post once it's a bit more complete.
Blue Blood is offline
Old 02-20-2012, 11:41 AM   #4665
62 Barnfind
62 Barnfind's Avatar
I removed the front broken glass, painted the inner fenders and core support.
62 Barnfind is offline
Old 02-20-2012, 11:43 AM   #4666
Blue Blood
Blue Blood's Avatar
^Cool 62'^
Old 02-20-2012, 06:07 PM   #4667
tincan1966
tincan1966's Avatar
Checked out a local salvage yard that has several '60-'66 trucks/parts. Scored an instrument cluster w/gauges for the 'Burb, also found 4 bucket seats from a mid-'60's van that are low backed and really cool.
Old 02-20-2012, 06:24 PM   #4668
jj1965
jj1965's Avatar
Talking Re: What did you do to your truck today?
Finished my engine repaint and 700r4 install a few bugs left to work out but drives really nice. Added four wheel disc and a new master cylinder also (not in the photo).
jj1965 is offline
Old 02-21-2012, 11:09 PM   #4669
doobiebro
doobiebro's Avatar
Size:  19.1 KBAfter long consideration whether to buy a original copper radiator or all aluminum I finally bought the aluminum rad and fit perfect. Also fab a trans cooler from an early mid 2000s ford ranger in between the radiator and grill...
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline
Old 02-22-2012, 02:43 AM   #4670
62-One-Ton
62-One-Ton's Avatar
In the last few days I have put the cab and front clip on a giant dolley. Removed all the glass. Started stripping down the driver side in prep for body work. Replaced the driver side fender with a "new" one. And decided to replace the driver side door as some one tried to remove the curve in the top front corner, and they tried to fix where the door and fender hit and screwed it all up.
62-One-Ton is offline
Old 02-22-2012, 06:38 AM   #4671
fasteddie1964
fasteddie1964's Avatar
Removed old battery box and ordered a new one.
Friends don't let friends drive Fords
fasteddie1964 is offline
Old 02-22-2012, 11:12 AM   #4672
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Repaired the gas tank sending unit float. It had a leak and I was worried about running out of gas.
A little JB Quik did the trick!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 02-25-2012, 04:18 PM   #4673
64shortbox
64shortbox's Avatar
Smile Re: What did you do to your truck today?
I installed footwell courtesy lights with door jamb switches in my 64. I scavenged a complete floor courtesy light set up from a 73 C10. The factory set up only has one floor light about dead center at the bottom of the dash. I felt that wasn't enough so I also grabbed 2 light & bracket assemblies from a square body Jeep Cherokee. I was already there pulling the front door checks off of it so I thought why not get the lights too. If you just want the single light like the factory has in the 73 C10's it will "ALMOST" be a plug & play. Here's what you will need though:
1) one 3/8" X 24 fine tap (For the door jamb switches)
2) one Q drill bit (pilot hole for the 3/8"X 24 tap)
3) one 1-1/8" hole saw (Pilot hole for the 73 door jamb wire grommets)
4) soldering iron, flux, solder & some heat shrink tubing
5) two door jamb switches 1 rear door jamb switch from a 76 Cadillac for the drivers side. The C10 switches didn't work (too short to turn off the lights with the door closed) & the Caddy switch was too long for the passenger door of my 64 still trying to fiind one that will work for the passenger side.
Don't pay any attention to the wiring harness boots they aren't needed. I plan on installing power windows & locks in the future, but they came off a Ford Bronco if you were wondering.
If you plan on not adding the extra lights from a Jeep Cherokee ignore the second picture too. The light & bracket on the left are as pulled, the light & bracket on the right have been modified for GM connectors & to fit the dash of a 60-66 truck.
64shortbox is offline
Old 02-25-2012, 04:37 PM   #4674
64shortbox
64shortbox's Avatar
I took the jumper harness of the 73 C10, I removed my fuse block and cut the factory courtesy light leads and soldered in the 73 leads where I cut out my old wires. I used 2 lengths of shrink wrap per soldered joint for tha extra margin of safety.
The first picture is the factory lead from the 64 fuse box.
The second picture is with the 73 C10 leads soldered in place. If you look close you can see a little of my red shrink tubing sticking out under the fuse box. Darn!
Old 02-25-2012, 05:12 PM   #4675
64shortbox
64shortbox's Avatar
I got a little ahead of myself here. I drilled two 1-1/8" holes in the kick panels slightly above the bottom of the dash to run the wires and the grommets off the 73 C10 and I drilled the holes in the door jambs using the "Q" drill bit & tapped to 3/8" X 24 so I could install factory door jamb switches. Picture #3 shows the lead sticking out the passenger side door jamb switch hole I still need to find a jamb switch for the passenger side door. I also took a small thin flate blade screwdriver to release the GM male connectors from the 64 courtesy light connector I then pushed those into the 73 connector plug. It looks like it left the factory like that. The last picture is the finished job with the drivers door open and the footwell lights lit. Can you even tell anything has been done? No? Good that's what I was after. If you look closely you can see a slight glow from the right light reflecting off the A/C vent. Let me tell you though all those lights sure light up the truck cab at night. I also plan on sinking all the A/C vents in the dash and get rid of all the clutter mounted to the underside of the dash.
Closed Thread
