Old 02-17-2012, 02:12 PM   #1
jojoman
simple green on tires
I was just wondering wat harm would it be to spray simple green on billet aluminum wheels i got some outlaw II
jojoman is offline   Reply With Quote
Old 02-17-2012, 02:29 PM   #2
mcboomport
mcboomport's Avatar
Re: simple green on tires
I would make sure the wheel is wet first, just to be safe. I have seen some cleaners dull out the billet if you spray it without it being wet. I use simple green on all my billet. I have never had a problem with it. I also re-polish the aluminum everytime after a wash.
mcboomport is offline   Reply With Quote
Old 02-17-2012, 05:07 PM   #3
jojoman
You think it would take any like rust spots from them well they look like rust i know billet dont get rusty but these look like they have some rust spots some came off washing but others didnt
Old 02-17-2012, 06:03 PM   #4
76stepsidechevy
Just don't let it sit. I had that leave green streaks on my tires one time. It took a bunch of scrubbing with bleach white to get my tires black again.
76stepsidechevy is offline   Reply With Quote
Old 02-17-2012, 10:45 PM   #5
mcboomport
mcboomport's Avatar
It sounds like you need to sand/ buff them out. It can be done a number of ways. I've polished raw cylinders on my quads going through all grades of sand paper using wd40. You have to make sure you sand out the previous scratches. Starting with 220 and ending with 2000. It's a pain in the butt, but its cheaper than paying someone. My point is, depending how bad the rims are, you can work them back to brand new looking. If your rims aren't bad, you can start with a higher paper. Since your rims are already polished, you probably could start with 800 grit.
You could also use a hand grinder with buffing wheels. You can use the typical 3 steps of polishing compound. I usually finish with mothers, but it actually dull the aluminum if you buff them properly with the correct compounds.
Old 02-17-2012, 10:46 PM   #6
mcboomport
mcboomport's Avatar
Post some photos.
Old 02-18-2012, 08:17 PM   #7
jojoman
here a pic of wheels as you can see they look like dry glue on them from just sitting outside and i hit them with some of that air craft carrier paint remover to see if clear coat would come off but i dont thik the got clear coat and they not steel they aluminum so any help im thinking some steel wool what you guys think Name:  IMAG0030.jpg
Old 02-18-2012, 09:00 PM   #8
Newtz67
Newtz67's Avatar
Mothers aluminum polish and a mothers polish ball on a drill works great for me!
Newtz67 is offline   Reply With Quote
Old 02-19-2012, 01:22 PM   #9
jojoman
What about the white milky spots wat can i take those of with
Old 02-19-2012, 03:13 PM   #10
54Caddy
GM Addicted
54Caddy's Avatar
use steel wool and wd-40 start at like 1 and work down to like 000 grit. then after that get some mothers wheel polish and polish by hand too me it always looks better.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
