Dual tanks switch plate?
I have a '72 Sierra Grande with dual tanks and the lever to switch them is mounted between the driver's rocker and the seat on the floor pan.
There is a plastic plate to indicate which position the lever is in, is this a factory item and is it available? Many thanks! ![]() |
Re: Dual tank switch plate
im looking for the steal plate that tells you what way to turn the handle on the switch
im looking at a truck online used to have the three tank set up |
Mine was made of metal. Wish I didn't throw it away. I would have given it to you.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
So what year would those be?
20' Daredevil (Ret)
![]() Join Date: May 2003
Not factory.... most were dealer-installed aftermarket. Travel Tanks was one of the more popular ones, at least on the west coast. That's what I have and it has a plastic indicator plate.
Mine has a 'pointer' on the handle, at the short end opposite from where you grasp it to turn. Pointed end towards the rear selects the main tank (behind the seat)... point to the right selects right tank and point to the left selects left tank.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#6 | |
![]() ![]() Last edited by Sideways; 02-19-2012 at 02:00 PM. |
Found this picture online befor and this one looks like the one thats in one of the trucks im looking at online i be getting [IMG]
#8 | |
20' Daredevil (Ret)
![]() Besides the floor-mounted valve to select the tank, mine has a 3-way toggle switch under the dash for fuel gauge selection.
That looks like my switch but there is a plastic plate that is on the carpet that indicates which tank.
One of the seals in the lever went and the fuel wicked up the shaft and melted the plate. |
I bought a replacement at a local oriellys auto parts store but I had tried 4 other stores before I found someone that understood what I was looking for they called it some kind of valve but it didn't have any indicator plate with it, and my truck just has the 2 tanks so if you flipped it the wrong way if would just cut the fuel off
Posted via Mobile Device |
![]() Join Date: Feb 2011
My 70 has this sticker, but I believe you refer to the third photo...not sure where to obtain it. Boat supply business maybe?
MusicMan70 1961 GMC Suburban |
MusicMan70 i do not want the last one if the pictures you post it. im wanting to find the one that flat and thick as a dime or less , maybe should ask that guy name randy
#16876
Couple more for you.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#15 |
#16 |
Restoration Virgin!
Re: Dual tanks switch plate?
ttt
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#17 |
My 72 GMC K2500 has the exact same plate and mine has a factory auxilary tank with a filler neck in the beside right in-line with the cab tank style line. I have never seen them available in the aftermarke. I would assume the only option would be to restore it as best you can.
1972 GMC K2500 2006 GMC K2500 Duramax Clarksville, TN |
#18 |
Look for branding. I can't say there -wasn't- a factory option, but all the ones that I've ever seen, including mine, were dealer options.
So far as I know the factory option was for a single aux tank, but others will chime in... |
#19 | |
I might make one out of brass,engrave the faunt and have it chrome plated...or maybe do one in stainless. |
#20 |
hopeful i can and who ever eles able to find a plate
#21 |
"brand new second-hand"
sideways-Why not contact board member Teeitup or others who post parts for sale. Teeitup is always parting trucks as well as others and I'm sure they come across these pieces all the time. Good luck.
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
