Old 02-19-2012, 10:33 PM   #1
MARIOS68PANEL
Active Member
MARIOS68PANEL's Avatar
6 cyl tac or V8 tac question
I just got a 67 today. It was an original 6cyl truck.
It has a vac/tac cluster. I dont know if it is original. how can I tell if its a 6cyl tac or V8..Also it has no numbers around the tac. glove box tag says 04253AB Amp meter/oil gauge.any help would be great.
67 short step
71 Custom
MARIOS68PANEL is offline   Reply With Quote
Old 02-19-2012, 10:38 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: 6 cyl tac or V8 tac question
You will have to pull it out and see the back of the tach head for a stamp of "6 cyl" or the part number. Or hook it up and see how it reads.
Vacuum didn't come in 1/2 to one ton trucks and your speedo is a 71-72.
Definately added if not listed.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-19-2012, 11:25 PM   #3
Duncan and son
x2
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 02-19-2012, 11:35 PM   #4
MARIOS68PANEL
Active Member
what is the differance between the speedo`s ? why are there no numbers around the tach? any Ideas ?
And If I go back to cluster with gauges, Whats this cluster worth?
67 short step
71 Custom
Old 02-19-2012, 11:43 PM   #5
1972RedNeck
1972RedNeck's Avatar
My guess is the tach was added but the "number piece" wasn't changed.
I could have sworn I saw a 1/2 ton on here with a vac gauge listed on the SPID.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 02-20-2012, 12:01 AM   #6
too much stuff
Roadtrip!
Just a matter of changing the lens to a tach lens. Looks to be a decent cluster. Probably worth $250 needing a lens if the back is in decent shape.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 02-20-2012, 12:03 AM   #7
Livrat
Member #1049
Livrat's Avatar
The 71/72 speedos have a round hi beam indicator light where as the 67-70 ones were rectangular, the tach cluster looks odd because you have a non-tach lense
Livrat is offline   Reply With Quote
Old 02-20-2012, 12:14 AM   #8
MARIOS68PANEL
Active Member
another thing is it has an idiot light that says (Tandom Lock) on the fuel gauge side. never heard of that myself.
I have turned this into two threads.
67 short step
71 Custom
Old 02-21-2012, 05:17 AM   #9
burb71
Active Member
Tandom lock is for the med duty trucks, C/40, 50 & 60
No numbers on tach lens, lens is from a non tach dash
burb71 is offline   Reply With Quote
Old 02-26-2012, 04:32 PM   #10
seetheusa
I'm new so if I'm do'n something wrong I'm sure you'll let me know. the dash may be out of the big trucks c50 whatever the 6 tach in the one i got is cable drive like the speedo(and big block vettes)startes overreving at 3500 and that looks like air gauge not a vac.big tipoff.and yes some tight ass didn't spring for the correct lens.release the hounds!
seetheusa is offline   Reply With Quote
Old 02-26-2012, 04:41 PM   #11
seetheusa
ok at second look that could be a vac and on my tach the yellow to red colors for over rev are painted on the face of tach.as far as the cable drive on mine could be how they did it in 67.goodluck
Old 02-26-2012, 05:34 PM   #12
70shortfleet
70shortfleet's Avatar
The cable driven tachs for these truck are for diesel engine trucks and lens only go to 4000 rpms
70shortfleet is offline   Reply With Quote
Old 02-26-2012, 06:02 PM   #13
too much stuff
Roadtrip!
This is correct. From the front, you can not tell a 6cyl from an 8. Actually, if the numbers are gone on back, you can't tell that way either by looking.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
