help with coil springs please
I am looking at getting 2 1/2 drop spindles with either a 2 or 2 1/2 drop coil and i am going to run a big block how much more drop will i get if i use a small block spring verse a beefed up BB sping I would like a five inch drop in the front if not a little more thanks for any help
1969 c-10 swb
2008 HD 2010 Camaro 2ss (The Wife's Ride) 2005 Suzuki GSX-R 1300 "Busa" 1969 C-10 (under Construction) 2013 Sonic LT "LIVE LIFE,TASTE DEATH" |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: help with coil springs please
I'm pretty sure you won't get a definite answer to your question.
I would buy the 2" drop springs and trim them if you decide you want it to set a little lower. Anyone else have input on this?
Small block springs and big block springs have different spring rates for the difference in weight. It wont ride right. It would be like putting a ton of **** in the bed to lower the rear. Yeah its lower but it rides horrible.
