Old 02-20-2012, 11:03 AM   #1
ColoradoC10
ColoradoC10's Avatar
TH350 shift linkage question
I am building a new exhaust system for my 69 long bed. Does anyone make an aftermarket shift linkage that deletes the bracket that mounts to the frame? Or can I remove it and use the stock linkage? It would make a lot more clearance for my exhaust if I can do that.
Thanks for any help you can give me.
1966 C10 short step bagged 383
ColoradoC10 is offline   Reply With Quote
Old 02-20-2012, 11:26 AM   #2
Lee H
Lee H's Avatar
Re: TH350 shift linkage question
Someone has done that mod and posted picks. Might try a search. I'll poke around and see if I can find it.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-20-2012, 12:40 PM   #3
Livrat
Member #1049
Livrat's Avatar
I have used this setup in many different cars/truck
http://www.summitracing.com/parts/LOK-ACA-1800/
Livrat is offline   Reply With Quote
Old 02-20-2012, 02:13 PM   #4
Tim Christian
Tim Christian's Avatar
LOKAR makes one.
Tim Christian is offline   Reply With Quote
Old 02-20-2012, 02:39 PM   #5
ColoradoC10
Livrat, did that fit the stock chevy column with the TH350? Looks just like what I am looking for, thanks.
Old 02-20-2012, 02:44 PM   #6
hgs_notes
GEARHEAD
hgs_notes's Avatar
It's the same one I used. I had to make a small bend in the rod to get rid of some binding, but works great and was easy to istall.
hgs_notes is offline   Reply With Quote
Old 02-20-2012, 02:52 PM   #7
ColoradoC10
Thanks, just ordered it. Thanks all for the info.
