Old 02-20-2012, 05:39 PM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Can u tell from vin if a truck has 1" or 1.25" rotor?
see above
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 02-20-2012, 06:47 PM   #2
SBTork
Garage wrench
SBTork's Avatar
Re: Can u tell from vin if a truck has 1" or 1.25" rotor?
no sir
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 02-20-2012, 07:02 PM   #3
riz
Pull the wheel off and measure outside to outside of the rotor. You'll know right away.
RIZ
riz is offline   Reply With Quote
Old 02-20-2012, 09:43 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Check the RPO codes. Heavy Halfs, fleet trucks and special orders had them.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-21-2012, 12:14 PM   #5
Desert1957
Desert1957's Avatar
My 87 is a "Heavy Half" with 1.25" Rotors.
It has two RPO codes , "JB5" and "J55"
JB5 Brake System: Power, Front Disc, Rear Drum, 6400 Lbs.
JB5 BRAKE POWER, DISC/DRUM, 6,400 LBS
J55 BRAKE SYSTEM HEAVY DUTY
Desert
Desert1957 is offline   Reply With Quote
Old 02-21-2012, 01:18 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
The best way is to measure.
I had an '86 with the HD rotors and an '83 with the light duty rotors.
I'm not sure what GM was thinking.
I know all the 71-72 front ends are 1-1/4".
I think all the 73-80 front ends are also 1-1/4".
81-87 is anybody's guess,...
Keith
Convert to disc brakes.
Old 02-21-2012, 01:35 PM   #7
Keith Seymore
Keith Seymore's Avatar
Desert
Based on this I'm guessing JB3 would be the RPO for the smaller rotor.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-21-2012, 02:57 PM   #8
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I will pull the wheel and check it out. I was in front of the computer at work and was trying to figure it out.
Old 02-21-2012, 05:39 PM   #9
Desert1957
Desert1957's Avatar
K
JB3 BRAKE POWER, DISC/DRUM, 4,600 LBS
Dez
Old 02-22-2012, 08:14 AM   #10
Keith Seymore
Dez
Right. That would be the smaller power brake system.
I know there was a manual system available as well, JB1 perhaps?
It just occured to me that, during our recent move, I found the actual component charts that we use/used to release the specific brake hardware for the various systems - from 1979 or so. I'll see if I can find it again and post it up.
K
1979-1986
1986 - 2019
Old 02-22-2012, 09:55 AM   #11
flamingbig10
6.0 powered square
flamingbig10's Avatar
my 80 big 10 had 1" rotors that some one swap in, but it now has 1.25 rotors front and rear
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-22-2012, 10:23 AM   #12
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
off topic but kinda the same but I went to order front pads for my CC dually and they asked me what size my rear breaks were? the sizes were 13.2 1/2 or 13.3 1/2 where do i measure?
sorry for the thread jack
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 02-22-2012, 11:11 AM   #13
Desert1957
Desert1957's Avatar
K
K
Here is one of many resources.
http://www.c2e.info/rpocodes/gmrpocodesGthroughM.html
JB1 BRAKE, MANUAL DISC/DRUM 4300 LBS
Dez
Old 02-22-2012, 07:45 PM   #14
Keith Seymore
Ok - as I mentioned, here are the actual charts that were used by the design engineers to release the various brake components. You can see the hardware sizes, bore dimensions, friction material, etc and breakdowns by part number.
Based on the '87 chart it looks like the 1" rotor was used only on the two smallest systems, the JB1 manual and the lightest JB3 power. You should be able to tell by looking for your truck configuration on here:
1974 and 1987 shown:
I'll post the complete set as a reference in a separate thread.
K
1979-1986
1986 - 2019
Old 02-23-2012, 11:28 PM   #15
yellowGT
yellowGT's Avatar
easiest way is to stick your index finger in the holes that run along the edge of the rotors. I if you finger goes in its 1.25 if it doesnt its 1"
works for me. lol
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
