Paint code
I'm trying to determine the paint code on my truck. Is there a tag located anywhere that has that info? I want to figure out if my light blue and white 65 came from the factory with a white or ivory roof and insert between the body side trim.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
Re: Paint code
yeah there is a tag inside the cab on the left. it's close to where your left knee is when you're in the drivers seat.
![]() Join Date: Oct 2009
Re: Paint code
once you find the code, here's the key:
Also note that you'll only have one number on the trim tag. For instance solid light blue is 507. I believe that a white top/insert (if you had the side trim) would be a 537 (shown on the second pic only - a 1966 chip, but same logic applied). Last edited by jocko; 02-17-2012 at 02:13 PM. |
Re: Paint code
Thanks everyone.
Re: Paint code
Great info, Jocko, thanks!
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
#6 | |
Re: Paint code
Rollin' Old Skool
Re: Paint code
driver's side just to the side of the fresh air vent
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
Re: Paint code
That was great info, thank you. Does any one have a list of what the trim RPO's are?
Re: Paint code
Darn, all I have are holes where it's supposed to be... Thanks for the picture.
#10 | |
Rollin' Old Skool
Re: Paint code
Re: Paint code
Mine is painted over but looks like 521BA on a 64 suburban....is white accurate for 64 to?
Re: Paint code
yep. looks like 521 white was available from either 57-66 or 54-65 depending on which chart you read, either way you're covered. Not sure what the BA is though, hmm.
Re: Paint code
thanks, I assume white meant no two tone, so the BA confused me to. thanks for the info.
Re: Paint code
Sometimes its better to be lucky than good. In the back of my pea brain I started thinking after Likaroc13 posted the picture of his tag and started digging through the paperwork I found in my truck from the original owner and this was stuck in the owners manual. Now I wonder what the AD is after the 537 paint code that Jocko said was correct.
#15 | |
Re: Paint code
#16 | |
Rollin' Old Skool
Re: Paint code
another good question...i don't see anything stamped in the Trim portion of my tag
#17 |
Re: Paint code
Don't feel bad, mine is a 64 C10 swb fleet with the code of 528AA . I now 528 is Desert Biege or Fawn but the AA code I can't find it anywhere. The trim just says STD lol
![]() Last edited by kenmel; 02-20-2012 at 09:38 PM. |
