02-20-2012, 10:44 PM | #1 |
Questions: NON-80 lb oil pressure gauge and speed-warning dash
I was looking at the really nice dash that PT's70CST has for sale, but didn't want to fod his sale thread - figured it'd be better to ask a question here and others might benefit.
I see a lot of hub-bub about the 80 psi oil pressure gage - what is the max pressure reading on the "stock" non-80 psi gage? What exactly is the "speed-warning" feature and how does it work? Thanks! |
02-20-2012, 10:52 PM | #2 |
Re: Questions: NON-80 lb oil pressure gauge and speed-warning dash
60 PSI.
I may be wrong but I think the speed warning is adjusted like a clock hand to makes a noise when the pre-set speed is reached.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
02-20-2012, 11:01 PM | #3 |
Thanks!
02-21-2012, 08:40 AM | #4 |
Old member
Yep!
Here is the one out of my 71. I installed speed warning, Tach, Clock in mine. I have it out of the truck and resting in a nice lined box as of now. I installed all GPS Speed Hut guages in it back this summer.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
