At the body shop.
3/4 ton to half ton spindles?
Does any body make a drop spindle for a 3/4 ton that will use a 1/2 ton rotor and caliper.
Or get a 1/2 ton spindle and get it reamed to 3/4 t ball joints. Or what options is there. Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 3/4 ton to half ton spindles?
www.earlyclassic.com sells the "conversion spindles".
Give them a call. As far as I know,... they are the only company that makes these.
At the body shop.
Hey thanks for the info.
I also shouldve mentioned square body... But they do have that spindle. Posted via Mobile Device
Yep.
They make a set for that says "71-87"? Kinda weird, because the 71-72 trucks use a different upper ball joint and outer tie rod end than the 73-87 trucks. I would call to confirm with Stan this. My guess would be that these work with the 73-87 parts.
At the body shop.
I called them.. theyre an hour away from me.
Its my bro n laws crew cab square. Want to drop it 4/6 or so and i have a 5 lug 12 bolt for the cause. Were kinda torn on how to do the front. Stock spindles reamed for 3/4 joints and cut coils or spindles and clip one coil. Posted via Mobile Device
