Old 02-22-2012, 11:41 AM   #1
scott72
scott72's Avatar
Re: Reinstalling Headlight Switch Knob
I pushed the button in on the back, to get it out originally. It didn't seem like anything broke. It came out fairly easy at the time.
scott72 is offline   Reply With Quote
Old 02-22-2012, 11:54 AM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You need to push the knob all of the way in. Once you think the know bottoms out, the spring tab inside the switch should push up with the end of the knob then lock in place. If not you may have broken the switch. Do you have an aftermarket knob? WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 02-22-2012, 12:02 PM   #3
scott72
scott72's Avatar
I think it is the original, but not positive. Yeah, when it bottoms out, nothing latches onto it.
Old 02-22-2012, 12:48 PM   #4
Classic Heartbeat
It can't hurt to try LockDoc's remidy first, but if it doesn't work you need a new switch. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 02-22-2012, 03:24 PM   #5
68gmsee
Active Member
68gmsee's Avatar
I think it's the spring that breaks or sticks. You could try taking it off an spraying some WD in there. It might also help to clean the sliding contacts in it also. If that doesn't do it, local auto parts carry the switches.
68gmsee is offline   Reply With Quote
Old 02-22-2012, 12:01 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
That would be correct. You might try putting a little lube on the pointed end of the shaft.
LockDoc
Leon
