Old 02-22-2012, 06:05 PM   #11
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
it's not a good pic, but if you look on top you will see my original dash fascia. a straight 3'' bent steel piece.
once i found fiberglassforums.com everything sort of snowballed from there.
cab was painted, i used many a roll of tape and carnuba wax to keep it from sticking to my fresh paint.
i had some welded clips on the bottom of the dash that i re-used for the glass work.
both left and right wings are held on with the clips, so is the passenger side
you can see a better shot of the clips here,
you can also see the vintage air unit and how far down it hangs.
the pass side fascia is 4'' to cover up the va unit
va unit before ^^ va unit after vv
shop air compressor timer
