Old 09-10-2003, 07:20 PM   #1
TomC
Location: Morgan Hill, California. Just beside San Jose
Front spindle help
I sure hope you don't get fed up with all my questions, but this is the greatest information source around, and with the search not working, this seems to be the best way.
I have a 1970 3/4 Ton with 8 lug spindles. I have a chance at getting all the front end parts from an '87 Chev 3/4 Ton van with 8 lug. Will those spindles fit my upper and lower control arms? What would be required to have them mount on my '70?
Tom
1970 GMC Camper Special
1959 Nash Metropolitan
1994 Harley Road King
1997 Lincoln Mark VIII LSC
TomC is offline   Reply With Quote
Old 09-11-2003, 08:33 AM   #2
JJR
JJR's Avatar
Looked at Hollanders and an 87 3/4ton van is not a good swap. I have attached what Hollanders shows will work for a 1972 3/4 ton truck (I used 72 since it would have disc brakes):
You can get spindles off the following:
CHEVROLET FORWARD CONTROL 71-72 30 Series
CHEVROLET FORWARD CONTROL 71-89 20 Series
CHEVROLET FORWARD CONTROL 73 30 Series; non-removable carrier
CHEVROLET FORWARD CONTROL 74-75 30 Series; non-removable carrier, 13x2-1/2 rear brakes
CHEVROLET FORWARD CONTROL 76 30 Series; 13x2-1/2 rear brakes
CHEVROLET FORWARD CONTROL 77-84 30 Series; drum rear brakes, 13x2-1/2
CHEVROLET FORWARD CONTROL 85-92 30 Series; I.F.S., drum rear brakes, 13x2-1/2
CHEVROLET PICKUP TRUCK 71-72 30 Series
CHEVROLET PICKUP TRUCK 71-88 20 Series; 4x2
CHEVROLET PICKUP TRUCK 73 30 Series; non-removable carrier
CHEVROLET PICKUP TRUCK 74-75 30 Series; non-removable carrier, sgl. rear wheels (1-1/4" width rotors)
CHEVROLET PICKUP TRUCK 76 30 Series; 13x2-1/2 rear brakes (1-1/4" width rotors)
CHEVROLET PICKUP TRUCK 77-79 30 Series; 4x2, 13x2-1/2 rear brakes (1-1/4" width rotors)
CHEVROLET PICKUP TRUCK 89-91 2500 Series; VIN models "R/V", 4x2
CHEVROLET VAN 71 30 Series; disc brake
CHEVROLET VAN 72-73 30 Series
CHEVROLET VAN 74-92 30 Series; sgl. rear wheels
GMC FORWARD CONTROL 71-72 3500 Series
GMC FORWARD CONTROL 71-89 2500 Series
GMC FORWARD CONTROL 73 3500 Series; non-removable carrier
GMC FORWARD CONTROL 74-75 3500 Series; non-removable carrier, 13x2-1/2 rear brakes
GMC FORWARD CONTROL 76 3500 Series; 13x2-1/2 rear brakes
GMC FORWARD CONTROL 77-84 3500 Series; drum rear brakes, 13x2-1/2
GMC FORWARD CONTROL 85-92 3500 Series; I.F.S., drum rear brakes, 13x2-1/2
GMC PICKUP TRUCK 71-72 3500 Series
GMC PICKUP TRUCK 71-87 2500 Series; 4x2
GMC PICKUP TRUCK 73 3500 Series; non-removable carrier
GMC PICKUP TRUCK 74-75 3500 Series; non-removable carrier, sgl. rear wheels
GMC PICKUP TRUCK 76 3500 Series; 13x2-1/2 rear brakes
GMC PICKUP TRUCK 77-79 3500 Series; 4x2, 13x2-1/2 rear brakes
GMC PICKUP TRUCK 88-91 2500 Series; VIN models "R/V", 4x2
GMC VAN 71 3500 Series; disc brake
GMC VAN 72-73 3500 Series
GMC VAN 74-92 3500 Series; sgl. rear wheels
SUBURBAN 71-88 20 Series; 4x2
SUBURBAN 71-91 2500 Series; 4x2
You can get upper control arms from the following:
CHEVROLET FORWARD CONTROL 73-78 30 Series; non-removable carrier
CHEVROLET FORWARD CONTROL 79-93 30 Series; drum rear brakes, w/o hvy. duty susp. opt. F42
CHEVROLET PICKUP TRUCK 71-80 30 Series
CHEVROLET PICKUP TRUCK 81-88 30 Series; w/o hvy. duty susp. opt. F42
CHEVROLET PICKUP TRUCK 89-91 2500 Series; VIN model "R"
CHEVROLET PICKUP TRUCK 89-91 3500 Series; VIN model "R", w/o hvy. duty susp. opt. F42
CHEVROLET VAN 71 20 Series; disc brake
CHEVROLET VAN 72 20 Series
CHEVROLET VAN 72-83 30 Series
CHEVROLET VAN 84-92 30 Series; w/o hvy. duty susp. opt. F42
CHEVROLET VAN 85-87 20 Series; diesel
CHEVROLET VAN 93-96 30 Series; 30 HD, drum rear brakes
CHEVROLET VAN 93-96 30 Series; exc. 30 HD; w/o hvy. duty susp. opt. F42
GMC FORWARD CONTROL 73-78 3500 Series; non-removable carrier
GMC FORWARD CONTROL 79-93 3500 Series; drum rear brakes, w/o hvy. duty susp. opt. F42
GMC PICKUP TRUCK 71-80 3500 Series
GMC PICKUP TRUCK 81-87 3500 Series; w/o hvy. duty susp. opt. F42
GMC PICKUP TRUCK 88-91 2500 Series; VIN model "R"
GMC PICKUP TRUCK 88-91 3500 Series; VIN model "R", w/o hvy. duty susp. opt. F42
GMC VAN 71 2500 Series; disc brake
GMC VAN 72 2500 Series
GMC VAN 72-83 3500 Series
GMC VAN 84-92 3500 Series; w/o hvy. duty susp. opt. F42
GMC VAN 85-87 2500 Series; diesel
GMC VAN 93-95 3500 Series; 3500 HD, drum rear brakes
GMC VAN 93-95 3500 Series; exc. 3500 HD; w/o hvy. duty susp. opt. F42
GMC VAN 96 3500 Series; exc. Savana; w/o hvy. duty susp. opt. F42
You can get lower control arms from the following:
CHEVROLET FORWARD CONTROL 71-72 30 Series; 7200 lb. rear axle
CHEVROLET FORWARD CONTROL 79-84 30 Series; drum rear brakes, sgl. rear wheels
CHEVROLET FORWARD CONTROL 85-92 30 Series; exc. hvy. duty front susp.; drum rear brakes, sgl. rear wheels
CHEVROLET FORWARD CONTROL 93 30 Series; exc. hvy. duty front susp.; drum rear brakes, sgl. rear wheels, w/o 9L6 brakes
CHEVROLET PICKUP TRUCK 71-72 30 Series; 7200 lb. rear axle
CHEVROLET PICKUP TRUCK 73-80 30 Series
CHEVROLET PICKUP TRUCK 81-88 30 Series; std. duty susp.
CHEVROLET PICKUP TRUCK 89-91 3500 Series; VIN models "R/V", std. duty susp.
CHEVROLET VAN 72-78 30 Series
GMC FORWARD CONTROL 71-72 3500 Series; 7200 lb. rear axle
GMC FORWARD CONTROL 79-84 3500 Series; drum rear brakes, sgl. rear wheels
GMC FORWARD CONTROL 85-92 3500 Series; exc. hvy. duty front susp.; drum rear brakes, sgl. rear wheels
GMC FORWARD CONTROL 93 3500 Series; exc. hvy. duty front susp.; drum rear brakes, sgl. rear wheels, w/o 9L6 brakes
GMC PICKUP TRUCK 71-72 3500 Series; 7200 lb. rear axle
GMC PICKUP TRUCK 73-80 3500 Series
GMC PICKUP TRUCK 81-87 3500 Series; std. duty susp.
GMC PICKUP TRUCK 88-91 3500 Series; VIN models "R/V", std. duty susp.
GMC VAN 72-78 3500 Series
Note for lower control arms: This arm may have two different ball joints one being light duty, the other being heavy duty.
Hope this helps.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
