Old 02-27-2012, 12:47 PM   #1
sir_talk_alot
sir_talk_alot's Avatar
Opening a can of worms about 2wd lifts-prerunner style
ok, so lets get everyone riled up about this again, i have found old threads but they have died, i know dino over in the 60-66 section has a prerunner truck. im looking now at either switching my ideas to either my current 70 or buying another truck, to build the "prerunner" look, doesnt quite have to be as snazy and effective as dinos truck. so who has ideas on netting somewhere around 4-6in of lift out of a coil all the way around truck. ive heard of 3 in lift coils, but could you also run like 2 in coil spacers with those? would the control arms take that or could it never be aligned? the rear isnt as much as a prob, just because you could swap the trailing arms on top of the rear end and prob get close to 6 of lift. really dont want to do body lift because i want the suspension travel look more than just a lifted 2wd. pics and ideas? ive got some ill load later.
-Mike-
'94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s
sir_talk_alot is offline   Reply With Quote
Old 02-27-2012, 02:12 PM   #2
Michael Star
Re: Opening a can of worms about 2wd lifts-prerunner style
I don't think it will be a bad idea. Would be interesting to see a truck like this as a prerunner. Although a bench seat would make it a fun ride!!
Michael Star is offline   Reply With Quote
Old 02-27-2012, 02:18 PM   #3
sir_talk_alot
here are a few pics ive found, #4 being so extreme, all im looking for is the prerunner look, light bars and stuff i could have someone fab, but the 4-6 in of suspension is what im going for. maybe lift spindles.
-Mike-
Old 02-27-2012, 02:56 PM   #4
Michael Star
Those are cool! That white one is really nice. I say go for it!
Old 02-27-2012, 03:15 PM   #5
Tmwoodall
Agreed, the white one is cool. I'd like it even better if it were a stock step side that was massaged and flared to be pre runner style but a bit more oem looking.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 02-27-2012, 03:17 PM   #6
cam.man67
cam.man67's Avatar
That top stepper is awesome! Any more pics/info of that?
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 02-27-2012, 04:00 PM   #7
HARJO
HARJO's Avatar
Any idea where the white and black ones got those fiberglass front fenders? Them thangs are SWEET!
1968 Chevy C10:
4x4 conversion, 6" lift, 37" GoodYear Military OZ's, carb'd GMPP RamJet 350, Be Cool aluminum radiator, Flex-o-Lite electric fans, March accessory brackets, T350 trans, NP205, 4 wheel disc, fuel cell... etc.
HARJO is offline   Reply With Quote
Old 02-27-2012, 06:03 PM   #8
eastxbbqman
eastxbbqman's Avatar
Thats a lot better than setting on the ground. Those trucks are cool!
eastxbbqman is offline   Reply With Quote
Old 02-27-2012, 06:04 PM   #9
pooz911
pooz911's Avatar
check out this thread. different year but should work w/ your suspension.
http://67-72chevytrucks.com/vboard/s...d.php?t=442205
www.cardomain.com/id/pooz911
pooz911 is offline   Reply With Quote
Old 02-29-2012, 12:28 PM   #10
sir_talk_alot
that may work, i think that converting the crossmember with the 73-87 stuff, using the 73-87 1ton lower control arms, 88-98 lift spindles and calipers, and then getting lift coils for the front, and the spindles being 2.5, you could get 3in coils for the front, get new u bolts for the rear, swap the trailing arms on top of the rearend, and that should get the roughly 5-6in lift on a coil truck......sounds like a project for the future.......on another truck, not my 70, dont feel like tearing into my 70 right now, i think ill try this on a long bed. i dont know if coil or leaf rear, i think coil would be better with a good sway bar out back because of the way it flexes, and bounces well, compared to leaf that doesnt really flex as well, and you could get better bounce for small bumps/jumps with coils.
-Mike-
Old 02-29-2012, 12:49 PM   #11
txriverrat
Hanneman Fiberglass has these fenders, 3in. flare.
txriverrat is offline   Reply With Quote
Old 02-29-2012, 01:16 PM   #12
bbadfred
bbadfred
bbadfred's Avatar
I like the slammed trucks the best living in the land of Lincoln,but if we had any desert or hills a lifted two wheel drive would be really COOL!!!
bbadfred is offline   Reply With Quote
Old 02-29-2012, 02:24 PM   #13
sir_talk_alot
you are awesome, thnx for the link
-Mike-
Old 03-01-2012, 09:42 PM   #14
EOChev
EOChev's Avatar
Would have never thought of making a prerunner out of a 67-72 but seeing some done, they look pretty damn good
EOChev is offline   Reply With Quote
Old 03-01-2012, 10:19 PM   #15
1972RedNeck
1972RedNeck's Avatar
Why not just use a 4X4?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 03-02-2012, 01:02 AM   #16
sir_talk_alot
Everything. Dont want to sound like a jerk so ill explain. Prerunners are mainly 2wd, some 4wd, but the 2wd is better for these reasons- less stuff to break, less weight, independent front suspension, a truck with a live front axle is gonna jump, ride and handle like poo. not to mention get damaged on the terrain your screaming across. You want all the travel you can get to absorb the bumps and jumps. People assume prerunners are wanna be 4wds, people lift 4wds for ground clearance and bigger tires, preunners arent for the height, but for the suspension travel, you jack one way up and your center of gravity raises, defeating your ability to handle corners. Notice these trucks i posted and all trophy trucks/prerunners arent sitting high, and dont hav fender wells, its for the bounce. When you look up pics of trophy trucks, real ones are pretty much all mid engine 2wds.
-Mike-
Old 03-02-2012, 05:06 AM   #17
Cannon007
yea these are my favorite kind of offroad trucks. If there were any good places to run around on around my area I might be inclined to build one.
Yea about the 4x4 thing, when you see these trucks doing 90+mph over rough terrain its not about clearance its about smoothness and handling. When they go over a jump you see their full suspension unloads so its ready for the landing and settles down smooth and predictable.
Cannon007 is offline   Reply With Quote
Old 04-10-2012, 02:00 PM   #18
sir_talk_alot
http://giantmotorsports.com/content/view/85/105/ LOOOOOOKYYYYYYYYY. i found the solution!
-Mike-
Old 03-20-2014, 08:24 PM   #19
prerunner68
prerunner68's Avatar
That is in the future plans. I am putting the truck back together, it now has boxed lower a-arms with custom spindles, bypass shock and 22" of travel.
I am putting in a redundant msd ignition also.
Now why, Would you cut up a 68 to go play in the desert with??
prerunner68 is offline   Reply With Quote
Old 03-20-2014, 08:51 PM   #20
DreamRyder1963
DreamRyder1963's Avatar
I do not typically like lifted 2wd trucks but that white 67 is AWESOME!
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 03-20-2014, 08:58 PM   #21
lolife99
67-72 parts collector,…
lolife99's Avatar
How much to just sell your truck outright?
Keith
Convert to disc brakes.
Old 03-20-2014, 09:00 PM   #22
Cali72K20
Cali72K20's Avatar
Looks like this back in the day...
I'm not sure about a can of worms, it has been done before.
http://www.mecum.com/auctions/lot_de...=LA0713-158205
Cali72K20 is offline   Reply With Quote
Old 03-20-2014, 09:13 PM   #23
Cali72K20
Cali72K20's Avatar
http://www.fourwheeler.com/news/1307...auctioned-off/
Love this thing!!!
But that picture of the white one looks way better for suspension and steering.
That black one looks like Pismo/Oceano Dunes. I have never seen it out there, but I will be on the look out for next time I go.
Cool thread,
Casey
Old 03-20-2014, 09:44 PM   #24
Cali72K20
Cali72K20's Avatar
That site is not working? I hit the C10 I beam kit and nothing
Not to highjack, but I'm into jeeps too, always wanted to do a Jeepspeed type build. This has changed my mind. I would rather have one of these trucks to build up.
Old 03-20-2014, 10:08 PM   #25
prerunner68
Who?
