02-26-2012, 05:33 PM | #1 |
blinker trouble
I need some help with the blinkers on my 54. I am in the process of installing a Ez21 harness and I am testing as I go. I wired the blinkers and brakes lights and I can get them to come on but the blinkers do not blink. Any help would be great. Thank you. Josh
02-26-2012, 05:53 PM | #2 |
Re: blinker trouble
I take it that you have a flasher hooked up in your fuse panel? Also if you are using any type of LED light they require a different flasher. Also did you try it with your iginition on?
Just thinking out loud. Good luck Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
02-26-2012, 10:30 PM | #3 |
Re: blinker trouble
I am using the flasher in the fuse panel. I got it to work if I put more draw on it. I think I need to get a different flasher.
02-26-2012, 10:31 PM | #4 |
Re: blinker trouble
Thank you Marc
02-26-2012, 11:09 PM | #5 |
Re: blinker trouble
You will need one something like this one. http://www.ebay.com/itm/Flasher-Led-...item2ebbd5a259
You should be able to get it locally but the prices I have seen can be pretty stiff on them. |
02-27-2012, 12:41 PM | #6 |
Re: blinker trouble
The thing is I dont have led lights. I plan on upgrading down the road but have lights with 1157 bulbs in the back and the stock marker lights in the front.
02-27-2012, 03:27 PM | #7 |
Re: blinker trouble
i think your flasher is bad. the ezwire 21 has 2 flashers for blinkers and 4ways. swap them out.
i have led rear lites but standard bulbs up front, this was enough load to activate them.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
