Old 02-27-2012, 02:15 PM   #1
purebred
Intake manifold issue.
I have a 350 performance engine in my 65. When I bought it, it had a Holley 650 double pumper carb on it. I recently put a Edelbrock 600 cfm performer carb on it to try and get a couple more gallons out of it. I have a Weiand single plane intake, My question is should I go ahead and pay for a new performer dual plane manifold or am I just throwing money away? All in all it runs pretty good now butidle is not always smooth until it realy warms up, I have heard that single planes verses dual are a little different, should I pay the 150.00 or just stick with the Weiand? any input is greatly appreciated. Thanks
purebred is offline   Reply With Quote
Old 02-27-2012, 02:23 PM   #2
gofastnut
gofastnut's Avatar
Re: Intake manifold issue.
I have run both and the dual planes seem to have better manners at and off idle. They seem to be a little more daily driver friendly.
And I'm pretty sure you can pick up a good used for less than the $150. How bout it members, anybody willing to part with one for a good cause?
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 02-27-2012, 02:37 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I would think there would be much difference.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-27-2012, 02:47 PM   #4
purebred
I put a vacum gauge on it and it seems to have the right amount of vacum. What would the differences be? Any gas mileage change or is it just a torque verses rpm thing?
Old 02-27-2012, 04:00 PM   #5
11echo
It depends on what you want you engine to do! "IF" you want a drag racing screamer then a single plane is the way to go! "IF" with want a "burn across the intersection" engine then a dual plane is the right choice. It's a matter of physics ...it takes longer for a volume of air/gas to reach it's peak going down a "big hole" then it does a "small hole" (i.e. dual plane) ...SO bottom line is dual plane is "quicker", but single plane is "faster"! ... Vacuum reading won't change between manifolds at idle.
11echo is offline   Reply With Quote
Old 02-27-2012, 04:13 PM   #6
T Smith
T Smith's Avatar
The single plane you have, being a performance manifold, doesn't have a heat crossover which is the reason it has to warm up a bit. A good dual plane will have better low end torque and street performance, and most likely have a heat crossover unless you go with the RPM model.
T Smith is offline   Reply With Quote
Old 02-27-2012, 07:17 PM   #7
purebred
I am going to bite the bullit and get a new performer 2701 manifold to go with my 600 cfm carb.
Old 02-27-2012, 07:43 PM   #8
Corts60
Just here to tinker
Corts60's Avatar
I agree with above. Dual plane for torque, single plane for top end.
Old 02-27-2012, 08:01 PM   #9
awbrown
If you really want good milage I would find a Quadrajet with an electric choke , jet the primaries up 3 or 4 numbers and like the others said get a manifold with an exhaust crossover,the performer with the q jet pattern would be a winner.... 2101 ..........
awbrown is offline   Reply With Quote
Old 02-27-2012, 09:58 PM   #10
gofastnut
gofastnut's Avatar
Originally Posted by awbrown View Post
if you really want good milage i would find a quadrajet with an electric choke , jet the primaries up 3 or 4 numbers and like the others said get a manifold with an exhaust crossover,the performer with the q jet pattern would be a winner.... 2101 ..........
x2
Jeff
C-10 Club
Old 02-27-2012, 10:22 PM   #11
markeb01
Senior Enthusiast
markeb01's Avatar
If you want to save gas grab a strip kit and start leaning that new carb out. It took me quite a few changes and road tests to dial mine in. Edelbrock carbs are setup very rich from the factory.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-28-2012, 12:17 AM   #12
awbrown
I experimented with jetting for a year as I drove my 73 c10 180 miles to tech school ,tried a few different carbs and went from 8 mpg with an old 4jet rochester , to 12 miles per gallon with a qjet jetted with 74's on the primaries it always felt dead jetted at 68 so we kept bumping it up , got more responsive and better milage ..
Old 02-28-2012, 02:07 AM   #13
Captainfab
60-66 Nut
I agree that dual plane intake will be better for a street driven engine. Here is a used one at a good prive, if you don't mind doing a little cleaning.
http://www.67-72chevytrucks.com/vboa...d.php?t=511076
If you do decide to go new, consider a Performer EPS. It is basically a little more refined Performer, to squeeze just a little more TQ and HP. Plus you won't need the adapter plate to bolt a square bore carb on it, since it has a square bore carb pad.
http://www.summitracing.com/parts/EDL-2701/
Old 02-28-2012, 06:59 AM   #14
purebred
Markeb01 , if you don't mind me asking what did you finnaly do (Jet wise) to dial your edelbrock in? Jets and metering rods, would appreciate the info, thanks
Old 02-28-2012, 07:05 PM   #15
blackedoutharley
Don't waste money buying a new standard Performer manifold. The EPS is a great piece for the money and is a square bore so no adapters.
blackedoutharley is offline   Reply With Quote
Old 02-29-2012, 01:55 AM   #16
Captainfab
60-66 Nut
I might add that the Performer EPS can also be had with the front oil fill tube, if that is something that interests you.
