Old 02-22-2012, 06:47 PM   #376
Re: SGTUSMC '59 build
Old 02-28-2012, 02:10 AM   #377
sgtusmc
sgtusmc's Avatar
Here's my "before pic's". I had planned on getting some wet sanding done. But I ended up getting to sick to play. No telling when the "after pic's" will get taken...haha Just thought I'd share.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 02-28-2012, 02:12 AM   #378
sgtusmc
sgtusmc's Avatar
Old 02-28-2012, 05:58 AM   #379
Barney Rubble
Barney Rubble's Avatar
that is looking baaaadddd!
Barney Rubble is offline   Reply With Quote
Old 02-28-2012, 10:11 AM   #380
Kim57
Kim57's Avatar
Looking good. I like the exhaust out the side.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-28-2012, 10:41 AM   #381
usmc_butler
usmc_butler's Avatar
Sarge, looks cool wish you were closer so you could give me some pointers on how to do this! Cant wait to see how it looks wet sanded
"I'm as confused as a baby in a topless bar"
57 Fleetside Build Thread
usmc_butler is offline   Reply With Quote
Old 02-28-2012, 12:56 PM   #382
_Ogre
_Ogre's Avatar
looking good.
shop air compressor timer
Old 03-02-2012, 01:47 AM   #383
sgtusmc
sgtusmc's Avatar
Hey guy's, I'm having some problems with a new ignition switch I bought from classic parts. It's the stock 59 ignition switch. I'm try'n to wire it up to my 1988 wire harness and I'm not having any luck. My 88 harness has a green wire that is a ground. The 59 switch doesn't have the ground. It cranks over but the inj. arn't squrting. I can plug it back into the factory 88 plug that I removed from the keyed igniton column and it fires right up. Is there another year truck that has the ground switch in the igniton that will fit the 59 dash hole?
Old 03-05-2012, 09:18 PM   #384
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Looking good brotha!!!
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 03-10-2012, 10:03 PM   #385
sgtusmc
sgtusmc's Avatar
We used the old e-brake to open & close the cutout I made.
CLOSED
OPEN
Old 03-10-2012, 11:56 PM   #386
drivea55
drivea55's Avatar
very cool man!
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 03-11-2012, 12:58 AM   #387
Kim57
Kim57's Avatar
That's wild.
Kim
My build thread
Old 03-12-2012, 05:05 PM   #388
99 to Life
99 to Life's Avatar
I'm digging this truck more and more. Jeeeesh.
As for the stock ignition. Can you post what all the OG switch has on it?
Should just be BAT, COIL, START AND ACC the only thing I can think of is, you'd need something to trigger your fuel module (I don't know much about) so maybe that is what that green wire is all about. Some pics would be helpful.
I'd def like to figure that problem out, because I'm sure others have had that problem, like when you do and LS swap or something, how do you keep a original looking ign switch when you need to power the fuel pump.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 03-12-2012, 05:29 PM   #389
_Ogre
_Ogre's Avatar
this pic has me thinking about putting a parking brake on truk
using the stock brake arm on the floor
nice work
Old 03-13-2012, 02:23 PM   #390
sgtusmc
sgtusmc's Avatar
Thanks guy's for the kind words.
99 to Life- The ignition swith I bought from Classic Parts has. sol, acc, ign1, ign2, and battery. I checked the 88 wiring diagram and the green wire is the ECM ground input. I think the newer ignition switches from 67+ trucks and 81-91 dash mounted van ignitions had a ground input on the ignition switch. I need to make my way to Napa and look through their ign switches one of these days. I'm thinking that will start it up.
_Ogre- It fits the conture of the seat pretty good. The only issue is releasing it from the up position. You have to use your pinking finger to push the release or turn your hand. All I did was tack on a peice of 2x2 ingle iron on one side. I guess if you buy or make a shift/brake boot it would improve the look.
Old 03-13-2012, 04:27 PM   #391
_Ogre
_Ogre's Avatar
newer ignition switches have lights in them
lots of plastic in the dashes too,
maybe the ground is for the light?
Old 03-17-2012, 01:29 AM   #392
sgtusmc
sgtusmc's Avatar
All right fellas, finally made my way to Auto Zone and found the fix for my ignition switch. I found an ignition switch for a 82-90 P30 Chevy van. It uses a dash switch that is the same size as the stock 59 switch they also had the key cyl with key. Part #'s are Duralast LS411 ($17.99)for the ignition switch and Lock Smart LC14220 ($8.99) for the lock & key. They couldn't find the wire pigtail in their system for this P30 van. So I asked to see one from a 67 and it's the right one. However, they didn't have one in stock. I'll have to check NAPA later. By the way the stock 59 screw on ignition trim holder fit's this new switch. I hope this helps someone out. It has Bat, Acc, Sol, ign, ground 1 (which I needed) and ground 2.
Old 03-17-2012, 02:42 PM   #393
OrrieG
OrrieG's Avatar
That is good news, seems like about once a month there is a thread about finding a newer switch that will fit the stock TF hole. Someone might want to add it to the tech articles.
Old 04-01-2012, 08:53 PM   #394
sgtusmc
sgtusmc's Avatar
Well traded the 59 for a really nice 58 Ford. It's a Ford in a Ford so what more could ya ask for. I'll have pic's up soon.
Old 04-01-2012, 09:00 PM   #395
_Ogre
_Ogre's Avatar
oh the shame
Old 04-01-2012, 09:38 PM   #396
Barney Rubble
a typo surely, I thought he said Ford??
Old 04-01-2012, 09:41 PM   #397
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Hey!!! This is a family website!! Go easy on the "F" words!!
Say it aint so Sarge!!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 04-01-2012, 10:35 PM   #398
sgtusmc
sgtusmc's Avatar
hahahaha...April fools! I was afraid I'd get banned from the board with all the F words. Guess all the mods are out drinking!
Old 04-01-2012, 10:52 PM   #399
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Nicely done!!
Good thing it's not true, we'd all have had to band together and provide an internet intervention. LOL
Jason
Old 04-07-2012, 11:28 AM   #400
Madd Doc
Madd Doc's Avatar
[QUOTE=sgtusmc;3931131]Okay my pig has finally arrived. Thanks guy for allowing me to join the 4 holer club. I'm not sure which way I'm gonna take this truck. I was thinking about going stock, however, my wife really likes it. She was bumping her gums about a pink and off white ratrod...lol
Can I join the 4 holer club as well? Looks like you're on your way to a great project!
My build thread
http://67-72chevytrucks.com/vboard/s...14#post5273714
Madd Doc is offline   Reply With Quote
