02-23-2012, 09:31 AM | #1 |
73-87 lift in a 72
what makes a 73-87 lift kit different than a 1972? Can i make a newer lift kit fit in a 72 blazer? thanx for your help
formerly cooter |
02-23-2012, 09:37 AM | #2 |
Re: 73-87 lift in a 72
The length of the front springs. 2nd gen are 3" longer if memory serves.
02-23-2012, 02:58 PM | #3 |
so has anyone installed 73 up front springs into a 72? I am sure someone has but i cannot find it in search.
formerly cooter |
02-26-2012, 03:00 PM | #4 |
Correct. Rear springs are the same, but the front ones are longer in later models. I know because the PO put '73+ springs on the front of my Blazer and the shackles/rear eyes are pushed up against the frame. I called Skyjacker to verify the part number on them. Too bad, they're almost brand new (as far as mileage goes) Skyjacker springs. I'd sell them, but right now I don't have anything to replace them with.
02-26-2012, 03:37 PM | #5 |
amazing how much more a lift costs for the 72 considering they are shorter! Superlift is the only 8 inch i could find for the 72 and they are on the edge of shutting down so i will buy a 73-87 kit and make new hangers for the front. thanx for the help
formerly cooter |
02-26-2012, 05:14 PM | #6 |
Sure thing. What do you mean Superlift is on the verge of shutting down? Going out of business or ceasing production of 8" springs?
02-26-2012, 09:15 PM | #7 |
apperently they are close to going out of business but they may have some major restructureing also
formerly cooter |
02-26-2012, 09:57 PM | #8 |
That sucks. My springs are Superlift, not Skyjacker. I always get them confused. When I had the money, I'd wanted to get front springs from them to replace the '73+ ones and match the rear.
02-27-2012, 01:08 AM | #9 |
4 wheel parts has the superlift 72 front springs in stock
formerly cooter |
02-28-2012, 11:34 PM | #10 |
well i figured a way around the 73 springs, since they are longer i will get them recurved which will shorten them and give me more lift and then just add a block in the rear. its like a win win
formerly cooter |
