02-27-2012, 10:31 PM | #1 |
PITbut
AN fittings? Where to buy?
Where do you guys purchase your stainless braided hose and AN fittings at? Local or online? I would like to make sure i have the right parts, i know what size fittings i need, but i dont know how that transfers over to AN numbers.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
02-27-2012, 10:38 PM | #2 |
Re: AN fittings? Where to buy?
each number in AN size is equal to 1/16th of an inch. 6 AN is the same as 3/8". I got my hose from summit and a hydraulic shop should have the fittings, I think they called them something other than AN. (FWIW "AN" means army navy)
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
02-27-2012, 11:11 PM | #3 |
PITbut
Hydraulic shop? I will call around. thank you.
02-28-2012, 03:23 AM | #4 |
i think summit racing has "their" brand AN fittings on sale right now.im looking into buying some also just havent decided on how im going to run my fuel lines yet -__-
02-28-2012, 05:14 AM | #5 |
summit for fitting or hose, i suppose jeggs and speedway are close in price. summit gets to my house fast at no extra cost.
02-28-2012, 06:04 AM | #6 |
Collector of Projects
I always heard, dont mix and match. Pick a brand and stick with one or you may have issues...
02-28-2012, 02:18 PM | #7 |
not being able to interchange fittings does not make sense to me. fairly sure they're all made to the same mil spec. however i stick with same brand hose ends to same brand hose.
02-28-2012, 02:23 PM | #8 |
67-72 parts collector,…
Jegs.
Good quality and price.
02-28-2012, 04:03 PM | #9 |
Also if you don't like the braided look, aeroquip makes a "pushlok" hose and fittings which I like. The hose is much easier to cut and is black. It does not have the steel brad and is NHRA approved.
02-28-2012, 05:34 PM | #10 |
Junior Member
Anyone using this for fuel lines? Does ethanol effect it?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
02-28-2012, 06:35 PM | #11 |
I've got a ton of XRP AN fittings in pushlock and braided. Let me know what you are looking for. Maybe I can help
Posted via Mobile Device |
02-28-2012, 06:41 PM | #12 | |
PITbut
6 feet of -6an stainless braided hose 804606ERL 829066ERL 829006ERL. Pic of each part. Part coming off the fuel line Lemme know. This is the fitting coming off the fuel pump This is the fitting thats going to come off my back of my carb and go to my booster.
02-28-2012, 10:49 PM | #13 |
I am a Referee of life.
The flares not sealing is usually from mixing A/N and others.Most flare fittings are one of two flare angles but even the ones with the same angles may have some differences in them.Depth of fitting/flare may not allow the flare to seal is the most common one I have run across.IIRC the flare angles are generally 45* and 37.5* but I've been wrong before(Or so "ol' what'ser name"says).
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-29-2012, 12:04 AM | #14 |
If I remember correctly All MIL-SPEC AN fittings are 37 degrees. Hydraulic fittings come in both 37 and 45 degree fittings.
02-29-2012, 02:14 AM | #15 |
AN = JIC in the hydraulic world and they are a 37 degree flare. Hose and fitting sales them in a swag-loc also...No flaring needed. This is what I will be using for fuel and air lines. Also JIC is much cheaper than AN, but you dont get all the pretty colors if thats what your into?
