07-08-2008, 10:52 AM | #1 |
Senior Moment
Help on Heater Core replace
My heater core finally gave up the other day - antifreeze all over the floor
Any way, do I pull it from the AC unit or under the dash??? I'm thinking glove box out and under the dash; I'd hate to take the AC unit off the firewall Any help would be appreciated, Oh ya it’s a 1970 with AC Thanks Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
07-08-2008, 11:17 AM | #2 |
The Older Generation
Re: Help on Heater Core replace
I don't know a lot about the air units but I'm betting it's on the outside.... Hoping someone will say I'm wrong for your sake. To get the outside air box off you have to take the inner panel loose, and I think the hood hinge off to get to a couple of the screws/bolts and get the box out. LockDoc
07-08-2008, 11:24 AM | #3 |
Chevy nut
I am almost sure you have to pull the box off the outside. I seen and air box at the junkyard off. The core was mounted to the outside box.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
07-08-2008, 12:47 PM | #4 |
The AC heater core is inside. You need to get the box behind the glove box out. The heater hoses are disconnected from under the hood. There are studs sticking out of the heaterbox that need to be taken off from under the hood.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
07-08-2008, 03:44 PM | #5 |
+1 on MREIN's reply (comes out from inside) but, there ae some studs with nuts that come loose from under hood.... if you do a search there's a pretty detailed account of removing a heater core from an AC truck.
71 GMC 1/2 ton 4x4, 350, 350th 67 chev short step, 396, 350th 41 chev flatbed, custom bed, frame & suspension, 350, 350th |
07-08-2008, 03:44 PM | #6 |
With AC under the dash---without, under the hood with the hinge removal
07-08-2008, 03:58 PM | #7 |
Senior Moment
Thank You all. Now who wants to do it - LOL its like 107 outside today, NOT ME
07-08-2008, 04:08 PM | #8 |
It is going to be so much fun!! A couple of the lower nuts on the studs on the outside of the firewall are nearly imposible to get to with the inner fender in palce. Good luck!
72 Cheyenne Super 80 Silverado Blazer 2wd |
07-08-2008, 04:19 PM | #9 |
Moderator
107? Not a problem, just turn on the A/C
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
07-08-2008, 04:37 PM | #10 |
On removing those lower nuts from out side the firewall, choices are.... 1)completely remove the inner fender or, 2)drill a couple of large holes in the inner fender or, 3) what a lot of people do is just remove the lower bolts, and as many others as needed, that hold the inner fender in place, then you should be able to reach in there from underneath, through the tire well area and take the nuts off.
07-08-2008, 04:55 PM | #11 |
I am a Referee of life.
Just loop the heater hose back to the other connection on the block,then wait for cooler weather.I don't think you're going to need it right away.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
07-08-2008, 05:07 PM | #12 |
Senior Moment
More good info and your right I'm in no hurry to fix it. I already looped it
07-08-2008, 05:37 PM | #13 |
Project Junkie! Fishing Poor!!
Make sure that you purchase a made in the USA heater core. Those seem to fit the best. I have seen many here complain about the fit on the made in Mexico one that you get at most parts houses. I recently sold a made in the USA A/C heater core to a customer in Seattle that tried to install a made in Mexico core that wouldn't fit. He reported back to me to tell me that the USA one fit great. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
07-08-2008, 07:24 PM | #14 |
If you are going to replace your heater core - here is a very old thread that I posted pics on my heater core replacement (nearly 5 years ago). It just might be helpful!
Oh - and do it while it is warm - you will thank yourself! Have fun! ~jewels
68 C10 Red Step 350 my first child & main focus 58 3200 Apache LWB Step the upcoming project |
07-08-2008, 09:05 PM | #15 | |
Moderator
03-01-2012, 03:14 PM | #16 |
Heater core replacement is pretty straight forward. The heater core comes out from under the dash with factory air as follows:
Drain coolant. Remove heater hoses. Remove inner fender from rt. side. Remove 5 nuts from the fire wall mounting the A/C box(the A/C will not need to be disturbed in any way). At this point, inspect all hoses, control valves, etc. Now is the time to replace these items!! Now for under the dash: Remove glove box door. Remove glove box. Unplug A/C relay on side of heater box. Remove all ducts that are immediately on top of the heater box-usually resulting in ducts being destroyed in this year of vehicle due to age. Remove two 5/16" screws attaching mixing door assy. to heater box. Remove 3 5/16" screws attaching mixing door assy. to floor ducting. Slide the mixer door assy. forward and out of the way. Reach inside the heater box and unplug the fan relay, and remove wires from the box. Take the two 7/16" screws out of the box mounting it to the firewall. Remove the box containing the heater core. After removing the box, you can see that the core is held in place by two retaining brackets-one on the front, one on the back. These are held in with two 1/4" screws each. Remove brackets. Remove heater hose tube hold-down. Have a beer, you are half-way through!! Install new core into box. Install box back onto the firewall with two 7?16" screws ONLY. Reconnect all hoses. Fill with coolant. Start engine and bring to operating temp. Turn off engine and let the engine sit with pressure in the coolant system for 2o minutes. Check for leaks in the core, hose connections, etc. If there are none, reassemble. This job takes approximately 3 hours start to finish, not including the beer! |
03-01-2012, 04:10 PM | #17 |
20' Daredevil (Ret)
Hey Scott, welcome to the board from NorCal!
If an old thread's gonna be revived, that's the way to do it -- with a great first post, very detailed & informative!!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
03-01-2012, 05:09 PM | #18 |
Florida Edition
Also welcome from Central Florida....ditto on a great post (kept me from having to type all that up )
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
