Old 02-14-2012, 08:19 PM   #226
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: Project: "Full Metal Yellow Jacket" Build Thread
Raised the front end up today.
This pic explains why the Mustang II IFS actually supports
less weight in a typical street rod than it was initially designed to carry.
In the top image the stock Mustang V8 carried 1850 lbs on the front suspension.
The Pinto carried somewhat less at 1700.
The street rod only carries 1600 lbs due to the location of the engine.
Suspension 101
http://www.heidts.com/support_suspension_101.html
http://www.heidts.com/_uploaded_file...pension101.pdf
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-18-2012, 11:17 PM   #227
1Bad62Pro/Street
Talking Re: Project: "Full Metal Yellow Jacket" Build Thread
Few pics today.
Old 02-18-2012, 11:26 PM   #228
1Bad62Pro/Street
Some more.
Old 02-18-2012, 11:36 PM   #229
1Bad62Pro/Street
The rest of todays pictures.
Old 02-19-2012, 12:10 AM   #230
1Bad62Pro/Street
After adjusting the front coil-over shocks about an half of an inch the other day it seems after driving it a bit the springs have settled.
So I don't need to adjust them any more.
The Bump Steer, and the Anti-Dive have been corrected.
So now the geometry is just right
I took some measurements around the truck - in the front, sides, and rear at certain key set points and everything is true. The stance of the truck is set around the Mustang II IFS Clip.
Later (when I can afford it) I will purchase the Heidts Upper Tubular Control Arms for Mustang II Suspension.
Old 02-22-2012, 10:21 AM   #231
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Is that a bolt on front suspension?
If it is, where did you find it? I have been looking for a rack steering for my 63 everywhere but haven't had any luck.
I am looking for bolt on to replace the stock bolt on suspension and I am tired of playing games with the power steering conversion stuff.
Just want to drive the thing
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 02-22-2012, 03:53 PM   #232
1Bad62Pro/Street
Wink Re: Project: "Full Metal Yellow Jacket" Build Thread
Well Bud,
I have a Mustang II IFS Clip on my '62 from a 1976 Mustang II IFS (Manual Rack)
You can see the stub frame in this video.
I have never was a fan the torsion bar front suspension on these trucks, but I am a big fan of Mustang II IFS. (Don't like Pinto IFS.)
Most guys use the Mustang II IFS on thier Hot Rods, Street Rods, Cars and Trucks.
The most common 3 are -Mustang II IFS - Camaro - Nova Stub Frames.
In my application with the Mustang II IFS Clip I lost a lot of weight removing the torsion bar front suspension. Gained disk brakes and gained better ride quality and handling characteristics. If anyone chooses to go with this route you have to make sure the geometry is right. I also have 2" Drop Spindles on her too..
My father and I cut out the X out mainly so we can put the cross member for the TH350. When we got rid of it we had to Box and Relieve the frame to make it strong.
Heidts sells IFS Kits for:
'37-'39 Chevy Pick-Up
'40-'46 Chevy Pick-Up
'47-'54 Chevy Pick-Up
'55-'59 Chevy Pick-Up
Heidts also sells the Heidts Universal Mustang II Crossmembers
http://www.summitracing.com/search/B...I&autoview=SKU
To my knowledge I thought there were no bolt on applications for IFS's for 60-66 trucks. Until I searched again today! If it wasn't for you asking me I would have not did an extensive search.
So I have found something you might be interested in.
BOLT-IN FRONT STEER IFS for '60-87 GM/GMC Pickups -- A total bolt-in package:
http://www.jimmeyerracing.com/pu6.html
Also I found this:
http://www.unisteer.com/seach_by_veh...inion_kit.html
http://www.performanceonline.com/Rack-and-Pinion-Kit/
There is a company called Street Rod Engineering
http://www.streetrodengineering.com/...gllifskits.htm
that sells a Heavy Duty Mustang II Independent Front Suspension crossover kits for 1960-1966 Chevy/GMC Trucks.
M26062CT 1960-62 Chevy Trucks $439.99
M26366CT 1963-66 Chevy Trucks $439.99
http://www.ecklerstrucks.com/catalog...nsion&limit=96
Old 02-22-2012, 09:30 PM   #233
66-PMD-GMC
66-PMD-GMC's Avatar
Thanks for the info.
None of those are what I am looking for.
I am looking for a direct replacement bolt in cross/K member that incorporates a manual rack set-up. OR a manual rack system that I can use with all the stock stuff.
I do not want to drop the 63 pro-street truck much if any and I am just tired of looking for a power steering setup for my straight six 3/4 ton truck and the power steering gear box adaptor I got from CPP and 2 others were all garbage.
I need the cross member exactly like the stock one because I use the late 70's diesel GMC motor mount perches to mount my Pontiac motor and all of the other replacement stuff I find is all geared toward chebby small block powered trucks.
Thanks again for the info... but I will keep looking or just swap my frame to a 68-72 frame like I am my other 63 truck.
Projects..
440CID 2X4 Pontiac
Old 02-22-2012, 10:02 PM   #234
1Bad62Pro/Street
Roger that Bud.
I am just now looking at your build threads now.
I don't know how I missed it.
I should of looked at them sooner.
Yea, If I run up on something I'll give you a hollar.
I'll keep a watch on your progress of your truck
Hey post a picture of that 440 Pontiac motor.
I would like to see it.
Shoot fire...post some more pics of your truck.
You got a narrowed 9" hinney too..
Old 02-23-2012, 06:28 PM   #235
66-PMD-GMC
66-PMD-GMC's Avatar
I will try and remember to unwrap it and get some photos.
If I dig around I might be able to find some pics of it before I took it out of the firebird before I sold it.
Projects..
440CID 2X4 Pontiac
Old 03-01-2012, 06:53 PM   #236
1Bad62Pro/Street
Old 03-01-2012, 09:08 PM   #237
66-PMD-GMC
66-PMD-GMC's Avatar
Too bad your so far away. I would toss you some dough for that clean original hood.
Projects..
440CID 2X4 Pontiac
Old 03-01-2012, 10:12 PM   #238
1Bad62Pro/Street
I sold my original hood a couple of years ago to a member on here Aboz.
I kinda wish I would of hanged on to it. I just have to pay the body man extra now to fix my premo fiberglass 6" cowl hood Unlimited Performance Products sent me.
The way you see it is the way they sent it to me. It's in pretty bad shape. Pin holes, thin areas, and it's just chipping away on the outside as well on the inside.
It's like looking at the menu at every fast food burger place.
Boy that picture of that burger looks good....
So you buy it. But when you get it and open the wrapper it's throwed together, under cooked, covered in grease, and taste like crap. Just tears an Ole Boy up.
Any hoot. You live and learn.
Be nice if you can buy a better quality, better fit and better design for our trucks.
Harwood has the best fiberglass and carbon fiber hoods on the market.
They are super nice!
If more 60-66's request them they might be persuated to start making them.
http://www.eharwood.com/index.php
sales@eHarwood.com
Just to let anyone interested in buying a fiberglass cowl hood for the 60-66 trucks, there are 2 companies who make them. Unlimited Performance Products and US Body Source. Both have bad reputations.
Old 03-01-2012, 11:52 PM   #239
66-PMD-GMC
66-PMD-GMC's Avatar
[SIZE="2
[/COLOR][/SIZE]
The cowl hoods on 60-66's are not my style at all. I guess to each his own.
I had one that I got with my 63 truck and it was the first thing to go.
I like the stock GMC hoods best. I have one on my 63 Chebby. I may change it to a Chebby hood if I find a nice clean one. Maybe not.
About your truck.... Plan on painting that dude soon??
My 66 is coming apart tomorrow to be moved to the "new" 71 frame and get painted at the same time.
Keep up the good work
Projects..
440CID 2X4 Pontiac
Old 03-02-2012, 12:22 AM   #240
1Bad62Pro/Street
Thumbs up Re: Project: "Full Metal Yellow Jacket" Build Thread
Yea,
I gotta fix the doors a do a few more stuff to her then she will be ready for paint.
I have decided to paint her bright yellow with flames on the front and maybe on the rear fenders. Old school phat transitional color flames with outlined flame tips. My dad wants me to paint her semi-gloss black with flames...
I don't know.... I always loved yellow on old cars/trucks and hot rods.
Seen a yellow 69' camaro RS/SS once with flames like that and it was one bad mamma jamma. White, orange, red, blue, with white hand brushed outlined flame tips. You used to see it a lot done in the 50's and early 60's. Now guys don't do flames like that anymore. Not a lot of people know how to paint flames the right way. I'm still looking for a good painter. Shouldn't be a lot of body work they will have to do. This truck has been a frame off restoration. Been a stocker, street rod, and now Pro/Street. I'll get her done one day soon. She don't look like much but I have little over $22,000 in her.
Old 03-02-2012, 12:57 AM   #241
66-PMD-GMC
66-PMD-GMC's Avatar
I disagree. Your truck looks like a lot of love has been put into her.
Projects..
440CID 2X4 Pontiac
Old 03-02-2012, 01:09 AM   #242
RockTonka
RockTonka's Avatar
mmmmmm, bacon cheeseburger!
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 03-16-2012, 09:16 AM   #243
1Bad62Pro/Street
Unhappy Re: Project: "Full Metal Yellow Jacket" Build Thread
Things I need to get.
1960-1963 CHEVY/GMC TRUCK DOOR LATCH ASSEMBLY, LH
1 38-6486 DOOR LATCH-LH 56.95 $56.95
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=12
Old 03-19-2012, 03:41 PM   #244
1Bad62Pro/Street
Angry Re: Project: "Full Metal Yellow Jacket" Build Thread
Dang doors!
Done!
ORDER SUMMARY:
________________________________________
Order # XXXXXXXXX
Order Date 03/19/2012 (Monday)
Order Total $70.70
Part # Description Qty Price Total Status
38-6486 DOOR LATCH-LH 1 56.95 56.95 In Stock
Your order will ship to:
1Bad62Pro/Streets Bat Cave!
Old 03-22-2012, 03:18 PM   #245
1Bad62Pro/Street
Just came in today. Now I got to put it on.
When I start working on the doors I'll order one for the other side.
Old 03-23-2012, 02:04 PM   #246
1Bad62Pro/Street
Got'er on and she shuts like a brand new truck!
Old 03-23-2012, 02:17 PM   #247
1Bad62Pro/Street
I can't pass this up when it's on sale!
JEGS Performance Products #555-10065
Super-Lite Starter
SB-Chevy (with Inline Bolt Pattern)
( 153 )/168 Tooth
7-1/4 lbs.
360 Degree Adjustable Mounting Block
http://www.jegs.com/i/JEGS+Performan...10065/10002/-1
Old 03-31-2012, 01:46 PM   #248
1Bad62Pro/Street
Ordered the Jegs Starter & Summit Trans Pan.
Old 04-01-2012, 10:34 AM   #249
66-PMD-GMC
66-PMD-GMC's Avatar
When are you going to take that truck to the dragstrip and get some times to post??
Projects..
440CID 2X4 Pontiac
Old 04-07-2012, 09:30 AM   #250
1Bad62Pro/Street
Ha ha
Never.....
I'm afraid of scattering it or run in to problems.
She is Pro/Slow...
Car Shows/Crusins and enjoying her.
People would laugh at me anyway!
Rice Burners would smoke me
