Old 03-01-2012, 05:04 PM   #1
ivorton74
ivorton74's Avatar
turn signal issue..help
i was just driving home from my uncle's house and turned on my turn signal and they dont flash...they just stay on. however it does flash if i turn on the hazards. anyone know what that is?
ivorton74 is offline   Reply With Quote
Old 03-01-2012, 05:23 PM   #2
vegas80step
vegas80step's Avatar
Re: turn signal issue..help
Did they work before? I'd check my turn signal flasher... I'm 95% sure you have a different flasher for the hazards...
I'm sure someone else will have more input...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
Old 03-01-2012, 05:25 PM   #3
vegas80step
had this saved on my pc....
Old 03-01-2012, 05:35 PM   #4
jhngardner367
jhngardner367's Avatar
I have to agree .Replace the turn signal flasher,and it should take care of it.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 03-01-2012, 06:10 PM   #5
MCCLELLAN103
MCCLELLAN103's Avatar
I had this problem, changed the flasher did not help the fuse was blown it should be where the P location is on the diagram above.
To Broke to be Fast
MCCLELLAN103 is offline   Reply With Quote
Old 03-01-2012, 07:30 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
flasher gets my vote,or ground
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-01-2012, 09:21 PM   #7
ivorton74
ivorton74's Avatar
thanks guys...ill have to check out that flasher. are they hard to change? and where exactly is it? was lookin in the workshop manual and it dont show it at all.
Old 03-01-2012, 09:27 PM   #8
donut
donut's Avatar
Swap the flashers around. I believe they are the same between the 2. If the turn signals come back, replace bad flasher. If not look deeper.
Easy to change, just 2 spade connectors on them. Pull them straight out.
The diagram vegas80step posted is the fuse block, look there. My '86 has the hazard flasher by the brake pedal, in case the fuse block doesn't have both.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 03-01-2012, 10:04 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
my 78
John
Old 03-01-2012, 10:29 PM   #10
ivorton74
ivorton74's Avatar
Originally Posted by motornut View Post
my 78
oh great...thank alot man...ill check it out first thing in the morning.
Old 03-01-2012, 10:31 PM   #11
Stepper562
Stepper562's Avatar
Same thing happened to me, flasher it was...
Stepper562 is offline   Reply With Quote
Old 03-02-2012, 04:33 PM   #12
ivorton74
ivorton74's Avatar
so problem solved...changed the flasher...turn signals blink again...thanks again guys for your help!
Old 03-02-2012, 04:53 PM   #13
TDS-MN
I never realized that there were 2 separate flashers for the signals and hazards.
'Course I have never had any issues with mine, so haven't had the need. But still, learn something new every day!
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
