Old 03-05-2012, 11:33 AM   #3376
funkytechmonkey
funkytechmonkey's Avatar
Re: 67 cheby's Dropmember build thread
They look awesome.... Hopefully mine will be installed by the end of the week.
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 03-05-2012, 11:39 AM   #3377
funkytechmonkey
BTW... Just saw your pics of the hard lines... You did good. Wish I would have thought about the clamps as spacers before I installed them. That was a good idea. Acuair should redesign those valves to be numbered 1-3-2-4 instead of 1-2-3-4. It would make more since because 1-3 are going to be on the sane side. It would make running the lines a lot easier and cleaner.
Old 03-05-2012, 11:43 AM   #3378
67cheby
67cheby
67cheby's Avatar
man no kidding on the way the valves are setup, it would have looked so much cleaner if they would have done that !
67cheby is offline   Reply With Quote
Old 03-05-2012, 11:43 AM   #3379
67cheby
67cheby
67cheby's Avatar
Originally Posted by nibs View Post
Very cool. Where did you get the tubing from?
Summit 3/8 aluminum line
Old 03-05-2012, 12:19 PM   #3380
Bennett68C10
Bennett68C10's Avatar
Looks good Mike, Does anything have to be done to the Accuair Valve Block to run the Aluminum Line. I really like the way that looks.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-05-2012, 12:32 PM   #3381
funkytechmonkey
The aluminum lines actually hold into the quick connects really well. I did the same thing on my build and was pretty pleased at how easy it was to bend the lines, mostly by hand, and it looks really good.
Old 03-05-2012, 12:41 PM   #3382
67cheby
67cheby
67cheby's Avatar
that is right man they really stick in there !!
Old 03-05-2012, 12:54 PM   #3383
funkytechmonkey
I ordered a few extra quick connect and a double sided quick connect from AVS and they are really nice. The connections are stainless instead of plastic. I got the double sided just in case I need to make a quick fix on the road.
Old 03-05-2012, 01:03 PM   #3384
watahyahknow
watahyahknow's Avatar
couldnt you just make an male female adaptercable or resolder the connections on the controllboxside to rewire the valves so the coils are set up the right way ?
the bends on the hardlines look good , its too bad you cant get different radius benders that go up in the same distance as the spacers you used that prolly wouldve made it eazier as the bends then all start at the same point over all the lines (you dont have to measure the stagger or finangle it so the distance after the bend is correct to use the spacers again) , would make it look cleaner too
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-05-2012, 01:31 PM   #3385
67cheby
67cheby
67cheby's Avatar
new pretty part !
Old 03-05-2012, 01:52 PM   #3386
es67chevy
es67chevy's Avatar
Is that one of those semi smoke stack covers? Just kidding. nice looking gas cap.
Eric
1967 C10 SWB
383 Stroker/TH400
Brother's One Piece Power Windows
Shaved Doors, Markers, and Bumpers
4/6 Early Classic Drop
Rear Fuel Tank (49-52 Chevy Car Tank)
Surf Blue Paint
Bella Vista, AR (Arkansas for those that get the 'A' states mixed up)
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869
es67chevy is offline   Reply With Quote
Old 03-05-2012, 01:54 PM   #3387
67cheby
67cheby
67cheby's Avatar
LOL, it's about the same size !! it's HUGE !
Old 03-05-2012, 02:28 PM   #3388
jasonhall
jasonhall's Avatar
Did you get it from the place that has your gas hole covered? same as n2billits cap?
jasonhall is offline   Reply With Quote
Old 03-05-2012, 02:38 PM   #3389
67cheby
67cheby
67cheby's Avatar
Nope...i am to cheap to spend $300+ on a gas cap, this was pushing it for me $134 from SPEEDWAY ! but it is a very nice piece,they make a large one and they also make a small one i think it is about $90 for the small one, this one is over 5 inches wide, i am impressed with the quality !
Old 03-05-2012, 03:43 PM   #3390
TXPinstriper
TXPinstriper's Avatar
Originally Posted by 67cheby View Post
hey a customer just sent me some installed pics of his SLOSH TUBZ , just wanted to share
Man those tubs look killer .....
TXPinstriper is offline   Reply With Quote
Old 03-05-2012, 03:54 PM   #3391
67cheby
67cheby
67cheby's Avatar
thanks , i was pretty pumped it is the first set i have seen painted to match !
Old 03-05-2012, 03:56 PM   #3392
watahyahknow
nice who needs a funnel just open it and dump a bucket out intoo the hole
it does look like a nicely made piece
Old 03-05-2012, 03:57 PM   #3393
67cheby
67cheby
67cheby's Avatar
LOL, its big enough you could !!
Old 03-05-2012, 04:31 PM   #3394
Slick67
Sofa King Crazy!!
Slick67's Avatar
A few excerpts from the last few posts.......
new pretty part !
they make a large one and they also make a small one.......this one is over 5 inches wide, i am impressed with the quality !
who needs a funnel just open it and dump a bucket out into the hole
Let's keep it clean guys.......
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 03-05-2012, 04:33 PM   #3395
Slick67
Sofa King Crazy!!
Slick67's Avatar
Those Slosh Tubz look awesome painted!!! Really cleans it up in the engine bay. Congrats on a great product!!!
Old 03-05-2012, 04:36 PM   #3396
edflores
Makes sense to me
edflores is offline   Reply With Quote
Old 03-05-2012, 04:37 PM   #3397
67cheby
67cheby
67cheby's Avatar
new pretty part !
LOL......this made me laugh so hard i almost cried !
Old 03-05-2012, 04:38 PM   #3398
Slick67
Sofa King Crazy!!
Slick67's Avatar
That's what I'm here for.......keep the seriousness to a minimum!!!
Old 03-05-2012, 04:49 PM   #3399
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
LMAO!
On a serious note, nice lines and plumbing!
Ryan
1969 Chevy milk truck
Old 03-05-2012, 04:55 PM   #3400
69CST-V
69CST-V's Avatar
I agree you should be able to pin out the connector to whatever you would need.
Nice job on the tube also.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
