Old 03-05-2012, 02:03 PM   #1
Bclanton
Bclanton's Avatar
Help with brakes 62 c10!!
Hey guys Im in need of some help. I have a 62 c10 with brake issues. I have replaced the MC and booster along with the rear brake hose. I have bled the system and I get pressure at the pedal with the engine off but with the engine running I have no pedal. We tried to bleed the system with the engine running and the rear wheel cylinder has very little fluid coming out. It almost seems as if the MC isnt being depressed enough. Does anyone have any suggestions?
Brandon
Bclanton is offline   Reply With Quote
Old 03-05-2012, 02:54 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Help with brakes 62 c10!!
Did you bench bleed the master cylinder? It very well could be your source of trouble.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-05-2012, 04:12 PM   #3
Bclanton
Bclanton's Avatar
Yes we did bench bleed the MC and again on the truck.
Old 03-05-2012, 05:57 PM   #4
blackedoutharley
Sounds crazy but....
Vac line to booster plugged or not hooked up properly?
blackedoutharley is offline   Reply With Quote
Old 03-05-2012, 05:59 PM   #5
Bclanton
Bclanton's Avatar
Checked that too even swaped vac lines on the carb to see if its any better. No change.
Old 03-05-2012, 09:24 PM   #6
62 mark
62 mark's Avatar
Did you replace these items because of a problem you were having before?Double check to make sure they gave you a 4 wheel drum master,if that's what you're running.Sounds like just lots of air in the lines tho...
62 mark is offline   Reply With Quote
Old 03-06-2012, 02:17 AM   #7
Captainfab
60-66 Nut
If you have a proportioning valve, and if the rear lines were at one point empty, the valve may have moved and mostly blocked the rear line. This is what it would do if there was a failure in the rear circuit. Check to see if you have good fluid flow at the rear brake port on the master. If so you might try re-setting the prop valve.
Old 03-06-2012, 01:13 PM   #8
Bclanton
Bclanton's Avatar
Thanks for the input guys... I will check it out and see if it works. Captainfab how would I go about reseting the porportion valve?
Old 03-06-2012, 01:18 PM   #9
Bclanton
Bclanton's Avatar
62 mark, the only problem I had previously was the booster was bad. We replaced it and the MC as an assembly. I wanted to upgrade the MC since I was replacing the booster I didnt think I would run into an issue with doing so. I will change MC with old one to see if that makes the diff. Thanks.
