Old 03-07-2012, 12:42 PM   #3426
67cheby
67cheby
67cheby's Avatar
Re: 67 cheby's Dropmember build thread
i am still in the build process on these hopefully into production by June or July , and i expect them to end up in the same range as the current ones around $559, and they will bolt in the factory bolt locations ! nothing for the back yet !
67cheby is offline   Reply With Quote
Old 03-07-2012, 07:18 PM   #3427
(joey)
(joey)'s Avatar
that hardline setup looks so clean.
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline   Reply With Quote
Old 03-07-2012, 07:21 PM   #3428
67cheby
67cheby
67cheby's Avatar
thanks man ! quite a pain with a cheap harbor freight bender and no experience....i killed alot of aluminum !!LOL
Old 03-07-2012, 08:46 PM   #3429
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Doesn't that bust your nuts when it's a long piece with many bends in it? I hate that when it happens!
Ryan
1969 Chevy milk truck
Old 03-08-2012, 12:02 AM   #3430
Tinkermc
Mike, last nite I read pages 1-75 tonight to 110 build looks great I agree with you the little things are very important and will set you apart from the masses. Hopefully Thursday nite I can catch up on the rest. Tinkermc
Tinkermc is offline   Reply With Quote
Old 03-08-2012, 01:21 AM   #3431
longbed67
longbed67's Avatar
Even with a good bender you can kill a lot of tubing!!! If only the stuff werent so expensive!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 03-08-2012, 01:46 AM   #3432
ajgriffin
ajgriffin's Avatar
I seem to remember that Earl's plumbing has some hard line that you can bend by hand (not with a hand bender, 5 fingers). I think it was on Gearz or something. I'll see if I can search it up or give them a call to see if I've lost my mind.
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 03-08-2012, 11:18 AM   #3433
67cheby
67cheby
67cheby's Avatar
well that sounds interesting !
Old 03-08-2012, 11:20 AM   #3434
67cheby
67cheby
67cheby's Avatar
Who thinks i should go ahead and add a PORTERBUILT BOLT ON BODY DROP... i mean since i am repainting my frame and stuff anyway, i mean this is the right time right...if i dont will i wish i would have ??????....SHOULD I ?
Old 03-08-2012, 11:37 AM   #3435
hahjoel
whats the benefit of the body drop?
69 GMC Long Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=500284
hahjoel is offline   Reply With Quote
Old 03-08-2012, 11:41 AM   #3436
funkytechmonkey
funkytechmonkey's Avatar
How much lower can you go? Arent you laying frame front and rear? AND... if you do the body drop wont you have to redo the chanel for the drive shaft?
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 03-08-2012, 11:54 AM   #3437
67cheby
67cheby
67cheby's Avatar
3/4 of an inch lower !
Old 03-08-2012, 11:56 AM   #3438
67cheby
67cheby
67cheby's Avatar
yes i will have to chanel the back of the cab just a little....just thinking out loud !! LOL
Old 03-08-2012, 12:22 PM   #3439
Lower
Lower's Avatar
Your already this far involved, might as well trim a little now before its all in paint!
~Jon
Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=516056
Lower is offline   Reply With Quote
Old 03-08-2012, 12:22 PM   #3440
YBNORML
YBNORML's Avatar
I have done it on mine. There is alot of things I did not think of before, but for you the most important thing to consider is will Slosh Tubz still work? If you drop the body 3/4 of an inch will you still have clearance?
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 03-08-2012, 12:28 PM   #3441
67cheby
67cheby
67cheby's Avatar
yes i still have the clearance
Old 03-08-2012, 12:54 PM   #3442
YBNORML
YBNORML's Avatar
Your lucky in that case, DO IT! Everything else is just a little cut/welding.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 03-08-2012, 02:10 PM   #3443
Bennett68C10
Bennett68C10's Avatar
Nows the time to do it Mike before you paint it, so I say do it.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-08-2012, 05:16 PM   #3444
67cheby
67cheby
67cheby's Avatar
Little update....I think this should TUCK about anything you SQUARE BODY dudes want to throw at it !
Old 03-08-2012, 05:28 PM   #3445
VA72C10
VA72C10
VA72C10's Avatar
SHOULD I ?
the fact that you're even considering it answers my question....if you don't...as you said....(slightly edited )
if I don't I will wish I would have
Old 03-08-2012, 05:31 PM   #3446
RustenPaines
RustenPaines's Avatar
who thinks i should go ahead and add a porterbuilt bolt on body drop... I mean since i am repainting my frame and stuff anyway, i mean this is the right time right...if i dont will i wish i would have ??????....should i ?
JUST DO IT!
If your considering it, after eight years and the gobs of money. Why stop at such a little thing.
69 C10 "Torchered"
RC Crawler Nut
http://www.dorkstarproductions.com/orcrc.com/forum/
RustenPaines is offline   Reply With Quote
Old 03-08-2012, 05:36 PM   #3447
RustenPaines
Oh yea, nice job on the air lines. Mad skills sir
69 C10 "Torchered"
RC Crawler Nut
Old 03-08-2012, 05:48 PM   #3448
67cheby
67cheby
67cheby's Avatar
Lol , thanks guys !!! I know I can count on other addicts to help with my decisions !
Old 03-08-2012, 06:52 PM   #3449
tubbedII
needs more $$$
tubbedII's Avatar
I don't know if I agree with the bdrop...I love the stance on your ride as it is now and don't see the need for any more drop. However, it would be just another damn awesome thing to add to the list that's on this ride...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 03-08-2012, 09:25 PM   #3450
ajgriffin
ajgriffin's Avatar
So I called them embed they confirmed that their hard line can be bent by hand. Not sure if I would change now considering all the work you've done but here it its anyway.
http://www.ANplumbing.com/Hose/Hard-Line-45.html
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
