03-06-2012, 09:32 PM | #1 |
Front Brakes Don't Work
Replaced my front rotors and calipers,master cyl, booster, proportioning valve and I did bench bleed the master before installing in my 72 PU.I have ran at least 3 Qts of fluid through the system using the Motive products power bleeder.I purchaed the rotors,calipers,and proportioning valve from CPP.Any thoughts or suggestions would be helpful.
Thanks,Kirk |
03-07-2012, 03:19 PM | #2 |
67-72 parts collector,…
Re: Front Brakes Don't Work
Does it seem like you have removed all the air from the system?
03-07-2012, 08:26 PM | #3 |
Thanks for the reply.I've bled them minimum half dz times and probably more.I checked for leaks and everything is tight.I talked to a guy from CPP today and he suggested gravity bleeding them so I'll try that tomorrow and I'm gonna check my vac press again.My pedal goes about a qtr the way down then catches but it's just the back brakes that work.If I pump it again they catch quickly but again it's only the back.
03-07-2012, 09:02 PM | #4 |
At the body shop.
Prop valve kicked over? Not allowing fluid to the calipers?
" That didnt make it any newer " " Dont antique the equipment " |
03-07-2012, 09:11 PM | #5 |
Stock style M/C?
Pedal rod the correct length? Silly question,... But the last problem like this,... the owner had the calipers on upside down. (wrong side of the truck) The bleeders were on the bottom.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-08-2012 at 10:03 AM. |
03-08-2012, 04:56 AM | #6 | |
Thanks,Kirk |
03-08-2012, 04:58 AM | #7 |
Bleeders on top pointed toward the sky.Thanks again for the help.
03-08-2012, 06:19 AM | #8 |
Are the hoses new? How well did they gravity bleed? I had a hose that was totally collapsed on the inside and it wouldn't gravtiy bleed, but it would let enough fluid thru for when my girlfriend helped me bleed the brakes.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
03-08-2012, 09:51 AM | #9 | |
Thanks,Kirk |
