Old 03-06-2012, 10:00 AM   #1
72ArizonaBurb
Pitchin (with a B) Products inner fender installation instructions needed
Does anyone have a copy of the *****in Products inner fender installation instructions? I bought a project from a fellow board member and the inner fenders came with no instructions. I am putting these on a 1950 Chevy truck.
It looks like I will need to trim the leading edge off to get the clearance I need at the radiator and I will need to notch the top of the inner fender to allow clearance for the fender brace that goes from the radiator to the outer fender.
Lastly my holes for the radiator support aren't lining up without some modification to my upper radiator support.
If anyone has these inner fenders installed and can upload some pictures by the radiator core support I would appreciate it.
If you have a copy of the instructions please email them to PittsCondor@gmail.com.
Thanks!
72ArizonaBurb is offline   Reply With Quote
Old 03-06-2012, 12:01 PM   #2
youngrodder
youngrodder's Avatar
Re: Pitchin (with a B) Products inner fender installation instructions needed
I will check tonight. I might still have my instructions. I installed their core support, floors, inner fenders and firewall in my 48 truck. If so I can scan them at work on Wednesday and provide you with a PDF file.
I will let you know.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 03-06-2012, 12:05 PM   #3
72ArizonaBurb
Thanks younggrodder. I think I have all those same parts. Did you use the original fender brace or did a replacement come with your parts? It looks like I have to cut out about a 1/2" x 2" section to allow that brace to clear. This also removes one of the holes in the inner fender.
Old 03-06-2012, 12:29 PM   #4
youngrodder
I didn't use the factory front fender braces. I made my own and tie in farther down (long story). Since My frame is not factory I had to trim my inner fenders several times to get them to fit.
Marc
Old 03-06-2012, 11:35 PM   #5
youngrodder
Well you lucked out...I found my instructions and it covers all of the P(b)itchin products. It is 35 pages in length. It might make sense for me to just photo copy it an send mail it to you.
Just PM my your address and I will mail it out.
Marc
Old 03-07-2012, 04:22 PM   #6
niper0108
niper0108's Avatar
I installed in my truck also. Front & rear floor kit as well. I also have all the instructions if you need them.
niper0108 is offline   Reply With Quote
Old 03-07-2012, 06:59 PM   #7
72ArizonaBurb
Youngrodder - Wow 35 pages. Some copy machines will scan and send via email. Do you have that capability at work? I hate for you to have to mail that big thing. But I really could use it. I will pm you my address and if mail works best then let me know what I owe you.
Thanks.
Niper0108 thanks also. Let me see if Youngrodder has me covered 1st.
Old 03-07-2012, 11:53 PM   #8
youngrodder
Thanks.
I will be going back into the office on Friday and I can scan the document and e-mail it to you then.
Let me know if this works for you.
Marc
Old 03-08-2012, 12:08 AM   #9
72ArizonaBurb
That will be fine. Thanks.
Old 03-09-2012, 09:21 AM   #10
72ArizonaBurb
Youngrodder - Can you send some pics of your inner fenders installed? I am also interested in how you have your A/C brackets setup. I have a new 5.3l engine with the serpentine belts. Not sure what power plant you have. The previous owner thought he would need to make a cutout in the inner fender for the compressor to fit on the passengers side.
Old 03-09-2012, 11:28 AM   #11
youngrodder
I looked for some pics when you first started this tread. I will need to go in the garage and take some this weekend. I'm running an LT1. More of my cutting had to do with the g-body frame and the steering shaft. My AC compressor is up high. I used Street and Performance brackets.
I have a PDF file of the instructions but the file is much too large (8 mb) to post to this site. Please PM your an e-mail address where I can send it.
Marc
Old 03-09-2012, 11:33 AM   #12
72ArizonaBurb
PM sent
Old 03-09-2012, 04:28 PM   #13
youngrodder
PM sent
Back at ya.....
**If anyone else needs this I now have a PDF that I can forward to anyone...
Marc
