Old 03-09-2012, 02:45 AM   #1
dme922
dme922's Avatar
1971 GMC 2 wd conversion
I am new to this forum and hope you guys can help me on my build. I have a 83 donor for my 4 wd parts but what im wandering about is the leaf hangers and any advice i can get on this build. My truck is equipped with rear leafs already. Any help or suggestion will be greatly appreciated.
dme922 is offline   Reply With Quote
Old 03-09-2012, 07:56 PM   #2
Mike C
Mike C's Avatar
Re: 1971 GMC 2 wd conversion
Not sure how the best way to combine all the parts would be. On 67-72, the 4x4 hangers are different than the 2x4. They lower the spring which is why 4x4 sits higher than the 2x. 4x4's also have 2 1/2" wide springs while the 2x4 has 2 1/4". Except Longhorns that had 2 1/2" wide leafs as well. I haven't looked at the parts Longhorn that I have in awhile to remember if the hangers are same as 4x4 or not, but I think they are. Longhorn also had 40" spring centers like the 4x4's.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-09-2012, 08:16 PM   #3
dme922
dme922's Avatar
Do you have any of the 4x4 leaf hangers
Old 03-09-2012, 08:18 PM   #4
dme922
dme922's Avatar
Would you happen to have any 4x4 hangers?
Old 03-09-2012, 11:07 PM   #5
dennislbrooks
dennislbrooks's Avatar
Lifts blocks and longer ubolts is one way to lift the orig 2wd rear and keep the same spring rate. You may need longer shocks and a longer brake flex hose depending on the lift. You can probably get away with 2.5" and not change shocks and brake hose.
As far as the front I used 72 springs and actually removed one leaf to get the height I wanted.
I can send any pic you want on the front as I converted my 67 c10 to a k10 using 69 hangers.
dennislbrooks is offline   Reply With Quote
Old 03-10-2012, 12:23 AM   #6
oldschool18
oldschool18's Avatar
are the leafs the same length on the 67-72 to the 73-87's
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
