Old 03-09-2012, 12:18 AM   #1
DnvrJay71
DnvrJay71's Avatar
3/4 ton swap 14 bolt Parking brake
Ok so I am just about finished with an axle swap to a 3/4 ton 14 bolt FF and gm 10 bolt up front.
How the heck do i make the parking brake cables work? I didn't convert it to disk brakes. I just want to use the normal parking brakes on the 14 bolt. It doesn't look like it's gonna be the right connections/ brackets/ length........ I don't know exactly what to do. How can I get my parking brake back without going to a line lock or transfer case ebrake? I just want to use the normal existing ones!
DnvrJay71 is offline   Reply With Quote
Old 03-09-2012, 02:33 PM   #2
drunkbus
New Member
drunkbus's Avatar
Re: 3/4 ton swap 14 bolt Parking brake
Here's how I did mine. Look on page 2, post #45.
http://67-72chevytrucks.com/vboard/s...=413741&page=2
drunkbus is offline   Reply With Quote
Old 03-10-2012, 08:07 PM   #3
Mike C
Mike C's Avatar
On my SF 9.5 swap I pulled the OEM Suburban cables off and re-used my original 12 bolt ones.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
14 bolt parking brake, e-brake, ebrake, parking brake
