Closed Thread
Old 03-10-2012, 09:37 PM   #4751
cb1965
cb1965's Avatar
Re: What did you do to your truck today?
started droping it. 3" spring up front then drove it around. got to lazy to do the back.
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline
Old 03-10-2012, 09:52 PM   #4752
Woogeroo
I took the blower motor out to try to figure out why it was squealing and making a racket.
I sprayed it good with electronics cleaner and reassembled... I may have to buy a new motor soon.
-W
Woogeroo is offline
Old 03-10-2012, 09:57 PM   #4753
fasteddie1964
fasteddie1964's Avatar
I put new spark plugs in, ran great then when I parked it the starter went out.....oh well
Friends don't let friends drive Fords
fasteddie1964 is offline
Old 03-11-2012, 01:29 AM   #4754
thebatii
thebatii's Avatar
pulled it down...motor need to come out ...tranny change and need to fix that starter issue .
took all day but its out, may not walk tomorrow but it was worth it . Ive been dancing around is forever. Cheers
thebatii is offline
Old 03-12-2012, 12:39 AM   #4755
dantimdad
dantimdad's Avatar
Removed the vertical drip rails, cleaned the insulation off the drivers side floor board and got it ready to cut out and weld back.
Also layed out the upper mounting position for the seat belts from the 94 silverado.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 03-12-2012, 12:48 AM   #4756
64shortbox
64shortbox's Avatar
The local self serve wrecking yard had a 1/2 off sale this weekend. I purchased a Power Brake pedal from a 73 C10 to graft onto my 64 C10 brake pedal. An idea I blatently and selfishly stole from doobiebro. Thanks for your help on this one doobiebro. I also picked up a couple of horns & a suspended throttle pedal assembly from the same truck that I do plan on installing.
Now here's the Kicker, after pulling my goodies I continued nosing around the yard just to see what I might find. One just never knows what you might locate. I SCORED!!!!! I've been wanting to add a radiator overflow container and windshield washers to our 64 C10 too. Under the hood of a full size Ford truck I found a radiator overflow & washer container with a built in pump. Lookiing it over I thought it just might fit in our 64. For 1/2 off I took the gamble. It's a Perfect fit with a little rearranging of the regulator & horn relay.
64shortbox is offline
Old 03-12-2012, 12:55 AM   #4757
AngryPirate
AngryPirate's Avatar
Cut, painted and installed a metal plate to cover the now vacant hydraulic clutch hole in the firewall. (similar to this: http://67-72chevytrucks.com/vboard/s...+firewall+hole )
Discovered that my valve covers where of the corvette L28 variety. Cleaned them, put a breather on the vacant hole (yes, vacant), new PCV valve and put them on the correct sides.
untwisted the spark plug wires, one at a time.
Pulled the dash instrument cluster.
Went to fire the truck up and it turned over fine, but wouldn't start/fire up. Double checked the ignition wires, still no luck. Ugh. Started it up the a couple of days ago no problem. Narrowing-it-down suggestions appreciated.
Other than that, productive day! Still a lot ahead though.
AngryPirate is offline
Old 03-12-2012, 01:08 AM   #4758
64shortbox
64shortbox's Avatar
If you notice you can see the 2 mounting points for the Ford washer/overflow bottle. You can also see how the bottle is angled to match the angle of the inner fender of a 60-66 Chevy Truck. For the pictures I removed the voltage regulator, horn relay & horn. I'm installing the 2 horns I picked up to each side of the radiator. I'm moving the horn relay & regulator to the other side of the radiator support and hiding them under that small panel cover to protect it all from rain & weather etc. Those Ford washer/ radiator bottles are in many cars & trucks. Most every Ford Exploder has those & so do the full size trucks. I think it looks right at home under the hood of the 60-66 Chevy trucks.
Oh, That overflow bottle looked like total garbage when I bought it. I filled the radiator side with full strength Zep brand Calcium Lime Rust remover - $10.00 a gallon at Lowe's. I let it soak for about an hour or so, then shoved a rag in it and scrubbed using a long screw driver then rinsed. I scrubbed the outside of the container using Awesome Orange cleaner - $1.00 a bottle at the Dollar Tree. I dried it all and sprayed a little Armorall on the lid to get the color back.
Old 03-12-2012, 04:40 AM   #4759
LinkbeltOE
I sand blasted the centers of my new rotors for my rear disk conversion
LinkbeltOE is offline
Old 03-12-2012, 08:21 AM   #4760
K98AL
K98AL's Avatar
Installed radiator support, grill, all associated sheet metal...and my new Champion radiator.
K98AL is offline
Old 03-12-2012, 10:51 AM   #4761
m455sx
m455sx's Avatar
Went from Idiot Lights to Gauges
1970 442 convertible
1970 Cutlass SX
1962 Chevy Stepside
2011 GMC 3500HD Crewcab SLT DRW
m455sx is offline
Old 03-12-2012, 01:27 PM   #4762
doobiebro
doobiebro's Avatar
Nice score 64shortbox.. Thats why I am addicted to this forum you find good ideas, good people.....
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline
Old 03-12-2012, 09:29 PM   #4763
fasteddie1964
Pulled starter off, called autozone gave them the number and they said it had lifetime warranty. They said bring it over and they would swap it out. Well when I got there they changed up on me and said manager would have to ok it. He wasn't there, be there tomorrow(trip for nothing) Oh well I guess I'll drive back tomorrow. (no problem, gas is cheap you know)
Old 03-12-2012, 09:47 PM   #4764
suzq044
Resident Photoshop Nerd
suzq044's Avatar
.. did more painting on the truck, until I ran out of tape 30mins later. lol
PJ - 1966 C10 Panel --
Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn
suzq044 is offline
Old 03-13-2012, 12:51 AM   #4765
Real_McCoy
Real_McCoy's Avatar
Started out to change the head gasket on the red 66 and then found the block was cracked. OK, so I have a spare I6 250 CID in the storage unit. As I was calling my buddy to ask to borrow his cherry picker, my neighbor who was hanging out with me called his buddy. We were just talking about the other 66 (white) and my plans for it. Turns out that I will be picking up a 283 CID V8 from a 66 Impala tomorrow for next to nothing.
We pulled the broken 250 tonight on the red 66. I will go tomorrow to pickup the I6 from storage and the 283. Did I mention the 283 comes with 194 heads and 202 heads. Which should I use? This is suppose to be a rare engine with a double roller cam or something. I don't know much about that, but I am stoked to finally find a 283 in my price range and when I had the extra cash. SWEET!!!
Daniel
66 Chevy C10 LWB
Support our troops!
Real_McCoy is offline
Old 03-13-2012, 12:59 AM   #4766
losthope
losthope's Avatar
I gutted and hid my air bag switchs and after market gauges in the under dash A/C unit my buddy gave me!
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline
Old 03-13-2012, 01:09 AM   #4767
AngryPirate
Pretty slick. Stealth-mode.
Old 03-13-2012, 03:06 AM   #4768
padresag
repaired some of the body mount brkts
these or the brkts just over the frt rear spring hanger
By rondavid at 2012-03-12
had spare good ones for the "b" pillar mounts- just more rivets to remove
what I had to cut out. not only is the hole enlarged , but they were dished out underneath
all ready for install. had to do the frt cab mounts to
ron
padresag is offline
Old 03-13-2012, 02:17 PM   #4769
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
what I had to cut out. not only is the hole enlarged , but they were dished out underneath all ready for install. had to do the frt cab mounts to
ron
Holy snot box!
I am sure glad I live in rust free Arizona! Dang Dude!!!
I feel for you guys in the north...
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 03-13-2012, 02:46 PM   #4770
1963c-10
1963c-10's Avatar
Hey, that turned out pretty nice. Now we gotta get you an OEM wheel to top it all off.
1964 Short bed trailer
1963c-10 is offline
Old 03-13-2012, 02:48 PM   #4771
AngryPirate
How did you do that? I have a 61 dash and I'd rather have gauges too.
Old 03-13-2012, 04:59 PM   #4772
zippeay
zippeay's Avatar
Well here it goes. I made and welded in patches on the back of my cab. I only took a few crappy pictures but you get the idea. I made both sides but I only got one side finished. I'm also replacing the floor pans, I've finished the passenger side already and now I'm working on the drivers side. I had to remake half of the front floor brace, I finished most of it last night but it got late and 4am comes too early... Hopefully I can get some more done today.
Here is the patch
Here it is welded up, still need to grind the welds
zippeay is offline
Old 03-13-2012, 06:40 PM   #4773
junk4cash
junk4cash's Avatar
Found my new/old air cleaner. I'm a junk guy so I always look for things while I'm out shopping, that I can use on my truck. My air cleaner was missing and I found this vintage silent butler at the thrift. Picked it up for a few bux and I'm going to use modify it and run it. Should be cool when I'm done. It's aluminum and dates from the 1930s. Has a great saturn/stars design on the lid.
junk4cash is offline
Old 03-13-2012, 07:14 PM   #4774
suzq044
suzq044's Avatar
maybe if ur truck was a Saturn.. jk
should look cool
suzq044 is offline
Old 03-13-2012, 07:15 PM   #4775
cb1965
cb1965's Avatar
switched steering wheel. from regular to deluxe
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline
Closed Thread
