Old 09-07-2003, 09:27 PM   #1
justplainjoe
justplainjoe's Avatar
steering wheel question
Does anyone know if the steering wheel from a 90s truck without airbag fits a 72 GMC without any mods.
justplainjoe is offline   Reply With Quote
Old 09-07-2003, 10:18 PM   #2
kaycee
kaycee's Avatar
yep
This is what alot of em are putting in now can usually find them pretty cheap.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 09-07-2003, 11:04 PM   #3
racedvl
racedvl's Avatar
Like this. . . ?
racedvl is offline   Reply With Quote
Old 09-07-2003, 11:06 PM   #4
imdarren
imdarren's Avatar
I just installed one tonight. Works great!
No modifications. Easy swap. If you have a steering wheel puller that is.
You can usually buy a used one for less than $60.
Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 09-07-2003, 11:20 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Me too...
I bought one from Nevada70chevy off of the parts board. Just installed it tonight. Took about 10 minutes total. You will probably need a puller though.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 09-07-2003, 11:49 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There are some small mods with the horn wire...make sure to get the wire from the donor truck.
Old 09-07-2003, 11:52 PM   #7
Benrs86
Benrs86's Avatar
$60 for a puller? you can never have too many tools, BUT a cheaper way is to get some steel, i used a tiny chunk of 1 by 1/4 about 3 inches long and drill two holes in it and you can screw it into the wheels hub so the shaft is on it and it will push it right off. bad explanation but if you look at your wheel you will see. goood luck, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 09-08-2003, 08:21 AM   #8
Tx Firefighter
Just buy a cheap harmonic balancer puller set. They work on steering wheels too. Make sure it's the type that can do two or three bolt setups. They usually cost under $20.
Old 09-08-2003, 10:40 AM   #9
justplainjoe
Cool, I'm gonna go out and look for one. The one on the truck is toast. I'm getting it ready to drive down from WA. Probally have it here in AZ by the end of Sept.
Old 09-08-2003, 09:23 PM   #10
imdarren
imdarren's Avatar
WoW! My bad!
That did look confusing the way I wrote it.
Is what I wanted to say is . . . . . .
You should be able to find a good used steering wheel for less than $60. Not a steering wheel puller.
Around $20 for a good NEW steering wheel puller.
Sorry.
Darren
Washington State
Old 09-08-2003, 09:40 PM   #11
cheatham
I need a brake!
cheatham's Avatar
Autozone rents the pullers for free, btw. $15 deposit refunded upon return.
JP
MEMBER OF THE DISCS UP FRONT CLUB
1971 Chevy C10
cheatham is offline   Reply With Quote
Old 09-13-2003, 10:11 PM   #12
justplainjoe
My wife found one at a yard sale today out of a GMC Suburban for 10.00, one less thing on my list to find.
Old 09-14-2003, 12:18 AM   #13
NuBomb
NuBomb's Avatar
Good Wife! If mine did something like that I would be proud (And Shocked!)
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
Old 09-14-2003, 08:41 AM   #14
jay6891
Car Knocker
jay6891's Avatar
With this swap, what upper bearing support are you guys/gals using? I used the one that came with the new steering wheel,for the horn button. and now I have slop in it and the turn signals won't cancel. Are you supposed to use the original from our trucks?
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 09-14-2003, 09:35 AM   #15
racedvl
racedvl's Avatar
I cut the upper bearing support from my old turn signal cam, and slid that onto the shaft first, then followed by the later model turn signal cam.
Old 09-14-2003, 10:47 AM   #16
Longhorn Man
I used the original one from our truck column, and modified the horn button wire.
