Headers
65 chev fleetside, Iam dropping in a 350 chev, do the shorties work better or are the longs a better install?
Re: Headers
I bought hookers ( headers that is ) and they slipped right into place without issue.
62 long box with a little SBC ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
60-66 Nut
Re: Headers
The long tubes are better for street performance. Are you running an auto trans or a manual? There are long tubes that will fit just fine. Hedman #69090 and Hooker #2452's. The Hedman #69260's are designed to fit these trucks with a small block.
Re: Headers
Be aware that the Hooker 2452's and Hedman #69090 have 1 5/8" primary tubes but the Hooker's have thicker flanges & 2.5" collectors vs. the Hedman having 3" collectors.
The Hedman #69260 have 1.5" primary tubes.. Somebody smarter than me will be able to explain the differences in pipe sizes to you. |
Who Me?
Re: Headers
I have a 61 fleet with a 305 and shortys. They have 2.5" flanges and they work great. I dont know the brand, they came with the truck.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Re: Headers
I have hookers(long) on my 66 327 v8 and I had to slightly modify my clutch linkage to clear the headers(manual trans), it just required a slight bend is all which was in the install instructions
Re: Headers
I guess I should have given all the info, I will be installing a 350 TH tranny with the 350 motor. I do appreciate all the replys, thanks
Re: Headers
I have headman longtubes with a 350/350 setup work great
But they hang down below the frame and im lowering quite a bit so im gettimg something shorter So depending on if your gonna lower your truck or not length may or may not be a factor to look at Posted via Mobile Device
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 Last edited by losthope; 03-13-2012 at 12:45 PM. |
