![]() Join Date: Nov 2008
Ok guys i got a 350 chevy engine complete...and to save money (cant afford 350 automatic trans yet....i thought i'd hook up the 350 to my 4speed trans....its got a 292 6 in it now...will the 350 sb hook right up totrans? using same pressure plate etc....what kinda motor mounts do i get?
can i use same radiator? thx for any help..never done this b4... |
Junior Member
Re: granny four speed to 350?
You will need V-8 motor mounts, a shroud, at least a 3 core radiator, a 350 clutch kit, a manual flywheel, etc.
I am sure others will chime in.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
You can use your flywheel, clutch and bellhousing. But you will need SB V-8; motor mounts, clutch Z-bar, eng. z-bar ball stud & mount bracket, rod (to the pedal), and trans.(bell housing) cross member. The 6cyl. and SBC V-8 4-speed trans. cross members are different. Pretty sure your driveshaft won't be the right length either. If your not going to leave it a 4-speed I would wait till your ready to put the TH-350 in it.
Z-bar might be the same. Last edited by airdale94; 12-28-2011 at 01:18 AM. Reason: add |
forgive pls..but can you tell me what clutch z bar..eng z bar etc are...i have pulled a few motors..but not quite an expert...
just want to get everything together before i pull engine...thx |
BLACK SATIN
![]() Join Date: Jan 2009
The Z-bars are your clutch linkage. I swapped a 250 for a 305V8 with headers & had to custom make the linkage. Maybe someone can come up with a picture. We were able to mount the 305 in the 6 cylinder mounting location & besides the distributor being very close to the firewall, everthing else worked.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new 67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering 85 C10 Silverado- 305ci Last edited by ges55; 12-28-2011 at 04:38 PM. |
ok just bought running 69 c20 truck ..has 350 small block with 4 speed trans...I have a rebuilt 350 here...gonna swap all the brackts..pulleys ..dist etc...onto the new motor and try to drop in this weekend..i hope the flywheel and trans hook up no problem..guess ill figure it out as i go
lots a good parts on the 69..cab seems solid no rust etc..desert truck...bed looks to be off a 72 or 73 to me...is a 3/4 ton..drove good...seems like it has p/s but it doesnt..strange...wish my 68 steering was that good with no p/s... i'll be listing parts on here pretty quick..so stay tuned.... anyone else want to give me tips doin my swap i'd appreciate it... thx |
Junk Yartist
Hey, Kevin! Just found your thread! I would love to help out with any questions! Talk to you tomorrow!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
hope this helps!
i put a 305 in place of a 250i6 and i wanted to do it so i could replace in the future with a 292i6. i used the original i6 bellhousing/flywheel/clutch/pressure plate and starter mtr and all associated bolts and linkages. the front crossmember mtr mounts stayed in the same place as did the gearbox x-member and driveshaft and i used v8 engine mnts. the i6 had the clutch z-shaft pivot bolt on a plate bolted to side of block so i made my own using a normal hex bolt that went went into the bolthole in the v8 block(note some blocks don't have this hole in which case i think you are in trouble)--i ground the hex to a round shape to fit inside the pivot shaft and used grease for asssembly--the linkage from clutch pedal to pivot shaft and pivotshaft to clutch release arm worked perfectly. the dizzy sits close to the firewall with no issues at this stage and a good size aircleaner fits as well--performer inlet manifold and 600 holley carb and normal dizzy wirth pertronic conversion. i used 3" spacer on water pump and a surburban fan and shroud. everything else was normal apart from bypassing resister wire from firewall wiring harness block to give full pwr to dizzy-same thing you have to do if using hei dissy. heres some photos ![]()
1969 stepside-305/4spd/12 bolt posi http://67-72chevytrucks.com/vboard/s...d.php?t=477157 1968 pontiac lemans convertible-350/pwrglde/10 bolt 1934 oldsmobile sedan-350/350/12 bolt posi 1930 model a pickup-350/350/jag ind 1928 model a roadster-283/350/9" |
in the above photos i still need to extend the plastic shroud to cover 1/3 of the fan to make it draw air properly.
some closeup photos the clutch pivot can be seen under the brake lines behind the ramshorn downpipe ![]() here it is again between the exhaust and steering column ![]() ![]() ![]() ![]() ![]()
Diddn't know if you kept the V-8 in the I6 postion you could use your I6 crossmember and driveshaft. Ahh!
C/10 junkie
Hey Kevin did you get the 350 in yet?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
the 350 is in and running awesome.....only thing was that my engine set back pretty close to firewall so my fan was quite a ways from the radiator...i fixed that by getting a fan shround for a 4x4...(longer snout)...my fan lined up perfect and it draws air and cools great....I was gona swap out the granny low 4 speed but decided to keep it and i'm glad i did.....
If you make a trip here ill give you my t350 and brand new uninstalld shift kit for that 4spd. Im kickin the idea around of a standard in my truck.
-Mike- '94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s |
C/10 junkie
Cool so other than the engine stands was it a straight swap?
#15 |
C/10 junkie
Hey Kevin can you post some pics of the clutch bar installed on the v8? Does the part that bolts to the block fit as well?
#16 |
will take some pix in a few an dpost on here..gimme a few..
#17 |
how do i upload pic? i have it on photobucket but cant figure it out
#18 |
C/10 junkie
Try this Kevin type this [img]put link here[/img]
| Bookmarks |
