Old 03-13-2012, 10:19 PM   #1
blongmire
blongmire's Avatar
just posting some new pics of my beater
guys that run front sway bars did you buy them new or is there a junk yard option that is an easy fit...?
blongmire is offline   Reply With Quote
Old 03-13-2012, 10:30 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: just posting some new pics of my beater
Welcome to the forum. I'm running a front sway bar and just used the one that came with the 75 front suspension I swapped in. The sway bar should be a simple bolt in on a 63-66.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-13-2012, 10:34 PM   #3
blongmire
blongmire's Avatar
hey thanks man i will try to track down a sway bar from a mid 70s truck and try the install thanks for the info.
Old 03-13-2012, 10:43 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
This thread should prove helpful:
http://67-72chevytrucks.com/vboard/s...ay+bar+install
Old 03-13-2012, 11:44 PM   #5
mbfiretech
mbfiretech's Avatar
what suspension setup do you have? i like that stance
mbfiretech is offline   Reply With Quote
Old 03-14-2012, 12:39 AM   #6
Captainfab
60-66 Nut
A sway bar fron any '63-'87 C10, 20 or 30 will work. The C20 Camper Specials and C30's have the largest diameter sway bars.
Old 03-14-2012, 07:52 AM   #7
T Smith
T Smith's Avatar
Nice looking truck, perfect stance and I'm digging the moons and rings!
T Smith is offline   Reply With Quote
Old 03-14-2012, 09:42 AM   #8
bsmith76
Second on the stance. I would also like to know what suspension you are running.
bsmith76 is offline   Reply With Quote
Old 03-14-2012, 12:25 PM   #9
blongmire
blongmire's Avatar
Well I put bags in the back where the coil spring was located and the front is on the stock bump stops I'm making brackets to put the front air bags on now.
