![]() Join Date: Aug 2007
Stainless radiator tubes SBC
I had two sets of these fabbed up for my project, you just use couplers for the connections, $50.00 for the pair +$13.95 shipping to the cont US
Scotts72C10 |
Re: Stainless radiator tubes SBC
Wow, those are nice, wish i could use them. My set up is slightly differant, been trying to find someone to make something like that up
Bump
Bump
Scotts72C10 |
Im interested again, changing my system....my outlet on the bottom comes out straight, how does yours come out of the radiator
Is your engine mounted in the forward holes of the frame or the back two?
Tube on the bottom comes out straight at the bottom and I used the forward mounts from Preformance on line with my SBC, you use short couplers to connect the tubes.
Scotts72C10 |
Really wish i could use these, they are nice! But, with my engine sitting in the rear mounting, and the angle of my water outlet, i just dont think these will work. Wish they would
Anyway, heres a bump for you Who made them for you?
My best friens is a aircraft builder, he built them.
Scotts72C10 |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
SHouldn't there be a short section of rubber hose at least on one end to allow for the engine and radiator to flex at different angles? It appears there are none in this setup.
Looks nice though.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
Junior Member
Very nice engine. Whre did the air breather come from?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
Ill look and let you know
Scotts72C10 |
Junior Member
Thanks, I can not find anything on them.
Scotts72C10 |
Would he build another set, somewhat similiar....
Could you get a overall lenght of the top tube, outside to outside, i might be able to cut your bend and put a rubber hose on it. Wouldnt look as clean as yours, but...
I dont hink he would build a tube unless your truck was here, I will measure it up tomorrow, both tubes are exactly 5" shorter than the stock rubber hoses, same exact bends and all, I think they would work perfect with any SBC application, I held them next to my stock 72 C10 set-up and I would only need to make the couplers 1/2 longer to use them, but its a stocker.
Scotts72C10 |
#15 |
Well, fat chance my truck will ever be in oregan
![]() Seems like the angle is differant than yours, i can rotate it, just cant change the up and down angle Plus mine is a 4X4, so the engine sits back about 2 1/2" ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-12-2012 at 09:02 PM. |
#16 |
If these are 1 1/2" tubing, ill take them, but before i do i would like to see a pic of the bottom tube installed
Do you have a pic of the coupling?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-13-2012 at 12:09 PM. |
#17 |
Top tube 1 1/4", bottom tube 1 1/2", just like the stock set up, the couplers are just 4" pieces of stright Rad hose with two stainless clamps or I used the Gates power clamps on the upper so it looks cleaner, I dont have a pic of the lower on, I have my core support off mounting the fenders, but it is the exact bends as the stock lower rubber hose, exact just shorter to allow for couplers
Scotts72C10 |
#18 | |
#19 |
PM sent, sale pending
Scotts72C10 |
