Old 03-14-2012, 03:36 PM   #1
murguia
How do I lossen my 70' Shor bed to adjust it?
So I just picked up an original 1970 cst 10 shortbed but the bed is slightly to the right, how do I go about loosening the bed up and aligning it correctly? Is it just a couple of big bolts or is it more than that?
murguia is offline   Reply With Quote
Old 03-14-2012, 03:41 PM   #2
no moa
no moa's Avatar
Re: How do I lossen my 70' Shor bed to adjust it?
There is a bunch, just climb under and see how many you have. If the has moved, some of the bolts might be missing. Should be 6 i believe.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 03-14-2012, 03:48 PM   #3
murguia
Sounds good, thanks man
Old 03-14-2012, 03:55 PM   #4
cdowns
cdowns's Avatar
lots of times if the bolts are original they cant b loosened and it is easier just to hack them off and buy new carrige bolts that are real cheap at the hardware store
Old 03-14-2012, 05:18 PM   #5
hugger6933
Before you go to the trouble of cutting or loosening bolts to move the bed, make sure that is your problem. It could be that your truck has been in a wreck sometime down the road[ you would be suprised how many used cars and trucks are rebuilt wrecks]. What I'm saying is that the truck could have had a impact in the side causing the truck to "diamond" or could have been hit in the rear or front making a shift. Or it could be as simple as the truck has had the bed sitting off to one side since it was new and you are the first to be bothered by it enough to do something about it. Measurments here will take a few minuites and may save a lot of trouble. Wheelbase Is where I always start the the distance between the front tire to the inner fender[ That one is important to me as late models have a crush point there for saftey] maesure the bed holes in an x pattern to see if they are the same [from underneath]same for cab mounts. If all of these check out fine thenyou are all square and then it is sheetmetal adjusting time. Good luck
hugger6933 is offline   Reply With Quote
Old 03-14-2012, 05:47 PM   #6
jchav62
1962 C-10
jchav62's Avatar
I agree. The cab has more adjustment than the bed and more often than not, the cab is what gives. In fact, the two front bolt holes on the bed don't seem to have any room for adjustment. From what I believe, during assembly (and on some of our re-assemblies) the bed gets put on first and then everything forward gets aligned to that.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-14-2012, 07:20 PM   #7
murguia
Thanks for the feedback guys. I'm going to put it up on a rack and check it out. If it does end up being the bolts, should I loosen the cab bolts or the bed bolts? Or does it differ between trucks?
Nick
Old 03-14-2012, 08:40 PM   #8
hugger6933
What about the hood gap? Is it wide on one side or does it taper from one end to the other stasrting off narrow and widening on one side and the opposite on the other. That would indicate cab misalingnment.Now the gaps on the bed to cab panelhow do they lookis it tight on one side and wide on the other or is the gap consistent? aconsistent gap could just mean the bed needs to scoot. Also measure [again with the tape!!!] From the framerail to the rocker front and back on both side then compare that measurement, if it is much off, the cab needs the attention not the bed. Now in the same vein you can measure from the frame to the corner of the bedside and front bed panel and see how close it is on each side that may help on what part to start with, And if you get into this you may need new cab mount and core support mounts to get all squared up . This will really help[ you in getting all the gaps right. Now I have told you all of this now I will tell you I have gone crazy with the same problem on S-10 trucks. I found out that the bed is wider than the back of the cab. That makes for some problems sometimes.
