#26 |
Re: parking lights weird problem
theres power on the parking light sockets when i turn on the signal lights,but not when the switch was just on for parking lights.. im guessing theres a separate wire going to the turn signal switch and another going to the headlight switch?
#27 |
Yeah
The park lights and signal lights are different circuits, they only share a ground. The turn signals work so that rules out the ground up there. Start checking at the headlight switch. I suspect you have a power problem. Posted via Mobile Device
#28 |
yea thats what i been thinking,on the diagrams it looks like they share ground, but cant really see where the power splits... i trace the turn signal wires to the cluster connector.. the other ones should go to the headlight switch?
#29 |
the brown wire from the headlight switch its spliced to a white wire,i think its for the alarm, i checked the red wire from the HL switch n has power,but how to test the switch or power when when you only have the knob just to turn parking lights or how many volts it should put up when headlights and parking lights are on?
#30 |
#31 |
IIRC, the brown wire at the headlight switch is the park light circuit.
You'll have to look at a diagram to see where it goes and how it splits. I don't have a diagram I can see on my phone. Pull the switch out to park and check the brown wire at the switch for 12 volts Posted via Mobile Device
#32 |
the brown wire should have power too?
#33 |
#34 |
yes the brown should have power when the switch is pulled out.
check dark green for power at the switch and check the orange for power at the switch
#35 |
Ok i just test the wires... brown 29.0,orange 29.0, yellow 11.80,green 26.7,white 34.2, red 12.. everything has power when knob its pull all the way..
Posted via Mobile Device |
#36 |
When knob its pull just for parking lights only white n red have power..
#37 |
Those numbers a off
Are you sure it's not milli-volts? Nothing should be over 12.5-13 volts Give me a minute to look at the diagram again... Posted via Mobile Device
#38 |
Sorry i did it wrong.. orange 11.2 mv, brown 11.2mv,yellow 11.6 volt,green 11.0 mv, red 11.7 volts, white 33.1 mv
#39 |
![]() Posted via Mobile Device |
#40 |
#41 |
Its that the ground for the cluster?
#42 | |
that is the fiber optic for the ash tray Ok, On the mV...A millivolt is one thousandth of a volt, so that means there is no power on the orange, brown, green, and white. so you have power on the red wire, that is battery power. The orange wire should have power also. It is fed from the tail light fuse. Check both sides of the tail light fuse at the fuse block to make sure you have power there. The green wire goes to the instrument light fuse, it should be hot if the headlight switch is in either position (park or headlights on). The brown wire goes to the park lights front and rear. It should be hot in both on positions also (park or headlights on). The white is ground for the dome and courtesy lights (it will show hot all the time until it is grounded. The yellow wire goes to the headlight dimmer, it will be on only when the switch is out for headlights. Does your courtesy light and dome light work? Now.... what is the blue splice on the brown wire in this pic
#43 |
What year is your truck?
I just went back and looked at some of your other threads. You have been having dome light problems? Dash gauge problems? You said this has an aftermarket alarm? looks like your wiring has been hacked, no? You might be better off with a new under dash harness.... Or at least remove all the aftermarket crap that has been hacked in and fix the cut wires. Does it have auto start?
#44 |
I got the dome light working.cigg. lighter never worked but didnt care much. It has regular alarm no auti start.. i check the alarm n wires looks fine.. i disconnected too to see if the alarm was causing that but still nothing..
#45 |
78K & 79C Jimmys
try with the switch in and meter on the brown wire ,both clicks @ the blue crimp on
this will tell if it's working that far then trace that brown from the crimp...that goes to the markers
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#46 |
i took off the harness from the firewall and fuse box to see on the back... there was 2 wires on the back of the fuse box almost off the connector and one of then was for the parking lights fuse...
#47 |
while disconnecting all kinds of connectors and stuff,i saw theres some with broken clips,kinda loose wires,etc,etc. its there a site to find the stock connectors to replace then?
#48 |
78K & 79C Jimmys
cool you got it!
you may get most of the plugs at a junk yard but knowing the right way to get the wires out helps,save the plug
