Old 03-14-2012, 09:00 PM   #1
dgas
C20 Lowering/RE swap ??????
I finally got a decent project truck not quite what I was looking for A C20 long bed fleetside strt six, 4speed ,8 bolt hubs- I wanted a C10 V8 3speed but ..in my part of the country you simply do not turn down anything in the sixties that is titled,complete, solid and unmodified. So now,what do I do w this beast? I want it lowered at least 2"/4" AND I want to get rid of that huge super low geared RE and four speed. In a perfect world I would even like to convert it to five stud lugs.
No pics yet but trust me it IS rock solid.
1966 Chev LWB C20 PU
http://s41.photobucket.com/albums/e2...ev%20C20%20PU/
dgas is offline   Reply With Quote
Old 03-15-2012, 12:46 AM   #2
Captainfab
60-66 Nut
Re: C20 Lowering/RE swap ??????
There's no reason you can't convert it to a 5 lug wheel bolt pattern. Everything changes out the same as on a C10. The exception to that is the lower control arm shaft is an oddball. It would be easiest to just switch the complete suspension crossmember with a '73-'87 unit. There is a way to go with 5 or 6 lug discs on the front by using '88-'98 components. Check out the 'Disc Brake Upgrade Reference Thread' That info is on the first page.
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
Ther are a lot of links to good info in the '60-66 FAQ' section up at the top of the page
There are a couple of options for the rear end. That depends on your cutting and welding skills.
Old 03-15-2012, 12:50 AM   #3
mud.man.rj
mud.man.rj's Avatar
That is the cool part on Gm's so much is interchangeable for cheap. A low, low 3/4 ton is cool too cause everyone has a C10.
mud.man.rj is offline   Reply With Quote
Old 03-15-2012, 11:46 AM   #4
chevyrestoguy
chevyrestoguy's Avatar
Find a '73-87 Chevy or GMC half-ton parts truck do the suspension swap. I did it on my '64 using a '79 Suburban. For the front, you'll have to drill two new holes and slot two existing holes in the crossmember. Buy a steering box conversion plate from Captain Fab. Buy a steering shaft coupling to mate the power steering box to your stock column from CPP. In the rear, use the rear axle from the parts truck. Just remember that it'll be 1.5" wider total than your stock axle, which isn't a big deal unless you want to go with a rim wider than 8" in the rear. Buy a rear axle perch kit from Brothers, CPP, Classic, etc. and weld them on. If you want to lower it more than 4", I would highly suggest a panhard bar relocation kit and a shock relocation kit. I got mine from Early Classic. To lower the truck, if you want 2" in the front, you can either cut a coil or buy a pair of spindles. In the rear, buy a pair of drop coils.
A conversion to 5-lug, power steering, and disc brakes take a bit of physical labor, but it's dirt-cheap and the benefits are fantastic.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 03-25-2012, 09:52 AM   #5
dgas
As my truck is a driver right now.(less head pipe. I will be going to a Clifford header set) I think I will just do a drop on it for now so I can still participate in this years cruise season. I will look for the parts to do a crossmember/RE swap next winter. Most of the catalogs I see only list C10 drop springs. Anyone know where C20 drop springs are sold? I want in the neighborhood of a 3/5 drop and will do a C notch in back.
Old 03-25-2012, 11:03 AM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
You can use the C-10 springs in your truck.
I do have some new lowering springs that came out the "project father/son 67"....just not sure what the drop is.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-15-2015, 09:51 PM   #7
TikiRodder
I just did a cpp 3/5 kit on my 1972 c20 it sits perfect with 255/55/18 will post pics as soo as I figure out how to
TikiRodder is offline   Reply With Quote
